  3. Spacing for IO pins
  • Views 16068
Spacing for IO pins
tswong
tswong over 16 years ago
Does anyone know how to set the absolute spacing of I/O pins when doing the I/O place inside the PREVIEW?  Can I set the value on I/O constraint file?
  • Alex Soyer
    Alex Soyer over 16 years ago
     Hello tswong,
    I guess you speak about 'Preview' in 5.1.41 or older version.
    You could use the 'Respace' feature or you could use the Floorplan File to do it manually.
     The I/O Place is more dedicated to Pads but could work with pins as well.
    Alex
  • tswong
    Alex,
     Thanks for you reply!
     Actually my module is small, but with high pin counts. It is very time consuming to move in manually. By the way, could you say more about the "Respace" feature and where I can find it....
     Regards, TS
  • Alex Soyer
    Tswong,
    Could you please tell me exactly what you try to achieve ?
    Because it seems you have already pre-constrained pins fom top level or from an other block and you would like to mimic the placement in this block.If it is teh case then I can propose some other way to do it.
     For the 're-space' you can find the command in 'Edit -> Soft Pins -> Respace'.
    You have the deatils on the command at:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=prfref/prfref5.1.41/chap7.html#1048770
    You need to search for 'Respacing Soft Pins'
    Alex
  • tswong
    Alex,
    I can respace the pin spacings now. Thanks!
    Regards, TS
  • Alex Soyer
    TS,
    You are welcome.
    Alex
