  3. How to import spice models libraries (*.lib and *.olb) in...
  • Replies 8
  • Views 15815
How to import spice models libraries (*.lib and *.olb) in cadence/virtuoso/spectre ?
lraf
lraf over 16 years ago
 Hello, I would like to use the vendor spice model libraries (*.lib , *.olb or *.cir) in cadence. Is it possible to import these libraries in cadence and then open the schematics in virtuoso and simulate in spectre ?
 Thank you in advance for your answers
Raphael
  • chanakaya
    chanakaya over 16 years ago
    Hello I am assuming that you are referring to the files created by OrCad Capture and Pspice. The extensions you mentioned are not files to be used if you want to bring in schematic from Capture to Virtuoso. It would be best to do a EDIF export from Capture of your schematic and then import it in Virtuoso. You might need to do some scripting to process the EDIF file before getting it into Virtuoso. regards, Ajish
  • HamidKhatibi
    HamidKhatibi over 13 years ago
    Hi Iraf
    I have the same problem, However I have my .cir or .lib file from HFSS.
    Could you find hwo to import it into Cadence schematic?
    Best
    There are numerous posts on this forum which describe how to reference an external SPICE netlist or model file from within ADE. Please use the Community Search capability to find these.
  • HamidKhatibi
    Thanks for your answer.
    I have already searched a lot and did not find anything. Would you please let me have one of those links?
    Best,
    Hamid
    From a quick search I found this blog by Tawna which describes how to do this.
  • HamidKhatibi
    Thank you very much again. I have seen these posts, but I use with Cadence, and I did not know that ADE means the same Cadence. Best Hamid
    Cadence is the company name, not the tool name. There is no tool called "Cadence".
    I am of course assuming that you are in fact talking about the Virtuoso Analog Design Environment and not the Orcad Capture tool or Pspice - because those are completely different tools mainly focused on PCB rather than IC design, and hence generally covered over on the PCB design forum.
    This is precisely why the forum guidelines ask you to state which tool you are using (and the version)
  • HamidKhatibi
    Yes, I use Virtuoso Analog Design Environment . Thank you very much, Hamid
