  3. License check sequence in IC6.1.3
  • Replies 22
  • Views 33895
Aramsh
Aramsh over 16 years ago
 Hi All,
Does anybody know how to set sequence of checking license features in IC6.1? I always need to use GXL
but it always goes to L, XL, then finds GXL. It takes a while as we have license in remote server.
Is there a way to force always look for GXL?
Thanks in Advance!
Aram
  • sunilm
    sunilm over 16 years ago
    Hi Aram,
    You can refer the following solution :
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11587412
     Regards,Sunil
  • Aramsh
     Hi Sunil,
    Thanks, but when I try to follow link, it says I need to register, however I'm loggid into the forum site.
    Aram
  • sunilm
    Hi Aram,
    The solution is there on the Cadence Online Support ( COS ) site which is different from the forum site.
    So, if you don't have the login for COS, I would recommend you to register on it to get lot of other good information.
    You only need a valid hostid and need to fill up the asked information.
    For your ready reference , I am pasting the solution here as it is :
    IC6.1.3.500.15 and later you can use the following way to specify a particular license order for various products. A new set of .cdsenv variables are now supported to cater to this requirement.
    license VLSLicenseCheckoutOrder    string "L,XL,GXL"
    The above is the default setting of this variable which indicates that checkout order is L license then XL license and then GXL license. You can change this .cdsenv setting to below to achieve what you want:
    license VLSLicenseCheckoutOrder    string "GXL,L,XL"
    Similarly, new variables are available for VSE and ADE also:
    license VSELicenseCheckoutOrder    string "L,XL"
    license ADELicenseCheckoutOrder    string "L,XL,GXL"
    Notice that for VSE, it specifies only L and XL because those are the only tiers available for VSE. One can alter above to change the license order for VSE and ADE.
    There are five new .cdsenv variables provided to support the old prompting functionality for using a higher license in case a lower license is not available. The defaults are:
    license VLSL_UseNextLicense        string "prompt"
    license VLSXL_UseNextLicense       string "prompt"
    license VSEL_UseNextLicense        string "prompt"
    license ADEL_UseNextLicense        string "prompt"
    license ADEXL_UseNextLicense       string "prompt"
    The valid values for these variables are:
    1. prompt: This is the default. If set, the Next License dialog is displayed each time a requested license is not available.
    Note: During a Virtuoso session, the Next License dialog will only display once for each application.
    2. always: If set, Virtuoso will always try to check out another license if the requested license is not available. For example:
    license ADEXL_UseNextLicense       string "always"
    This means, if ADE-XL license is not available, you will be always prompted before checking out ADE-GXL license.
    This means, if VLS-XL license is not available, you will be always prompted before checking out VLS-GXL license.
    3. never: If set, Virtuoso will never attempt to check out another license. For example:
    license ADEL_UseNextLicense       string "never"
    This means, if ADE-L license is not available, you will never be prompted for checking out a higher tiered license like ADE-XL or ADE-GXL.
    license VLSL_UseNextLicense        string "never"
    This means, if VLS-L license is not available, you will never be prompted for checking out a higher tiered license like VLS-XL or VLS-GXL.
    NOTE: The variables below has been discontinued due to the new set of variables:
    designEditor.license appsWhichAlwaysTryHigherTieredLicense string "Schematics L,ADE L,ADE XL,Layout L,Layout XL"
    designEditor.license appsWhichNeverTryHigherTieredLicense string "Schematics L,ADE L,ADE XL,Layout L,Layout XL"
    Sunil
  • Aramsh
     Hi Sunil,
    license VLSLicenseCheckoutOrder    string "GXL, XL,L" statement does not help.
     I still get the following....
    *WARNING* (icLic-3) Could not get license Virtuoso_Layout_Suite_L
    (deLicense-3) Could not get a license for Layout L. Trying a higher-tiered license
    *WARNING* (icLic-3) Could not get license Virtuoso_Layout_Suite_XL
    (deLicense-6) Checked out the license for Layout GXL to run Layout L
    Aram
  • sunilm
    Hi Aram,
    Few things to check :
    1. Make sure that you are using IC6.1.3.500.15 and later as the variables were newly introduced.
    2. Make sure that the .cdsenv file is read properly.
    For further debugging you can contact the Cadence Customer Support by creating an SR at http://support.cadence.com .
    Sunil
    Hi Aram,
    Which subversion of the IC tools are you using (Help->About in the CIW)?
  • Aramsh
     Hi Andrew/Sunil,
    I'm using IC6.1.3.500.10
     Aram
  • Aramsh
     Hi Andrew/Sunil,
     Aram
  • Aramsh
     Does this mean I can't use this feature with IC6.1.3.500.10 version?
    Aram
    Hi Aram,
    You'll have to use the older appsWhichAlwaysTryHigherTieredLicense cdsenv var that Sunil referenced earlier (these are obsolete after 6.1.3.500.15).
    BTW, the reason why having a forum login is insufficient for Cadence Online Support is that the forums are much more open than Cadence Online Support; for COS you need to be a customer with a maintenance/support contract - you have to give the hostid of your license server to register.
