  3. License check sequence in IC6.1.3
  • Replies 22
  • Views 33896
Aramsh
Aramsh over 16 years ago
 Hi All,
Does anybody know how to set sequence of checking license features in IC6.1? I always need to use GXL
but it always goes to L, XL, then finds GXL. It takes a while as we have license in remote server.
Is there a way to force always look for GXL?
Thanks in Advance!
Aram
  • Aramsh
     Hi Andrew/Sunil,
    Thannks for the answers! I have already registered in COS with host ID
    Best Wishes!
    Aram
  • Aramsh
    Hello again!
    I set the following in .cdsenv file in my home dir
    designEditor.license    appsWhichNeverTryHigherTieredLicense    string    "Layout L,Layout XL,"
    designEditor.license    appsWhichAlwaysTryHigherTieredLicense    string    "Layout GXL,"
     but still I see thatIC tries to get L and XL first
    *WARNING* (icLic-3) Could not get license Virtuoso_Layout_Suite_L
    *WARNING* (icLic-3) Could not get license Virtuoso_Layout_Suite_XL
    Can you please advice what's wrong?
    Aram
    Hi Aram,
    Without trying it, I think you have them back to front. I think you'd want the Layout L and XL to "Always" try the higher tier? (Not sure, I'd need to re-read the solution and I'm replying from a handheld devices so can't easily do that right now).
    To be honest, the reason we changed this in ISR15 to the new cdsenv vars was to improve the flexibility. Before that, you still got some warnings...
  • Aramsh
    I have tried this as well, but it does not work either....
    designEditor.license    appsWhichNeverTryHigherTieredLicense    string    "Layout GXL,"
    designEditor.license    appsWhichAlwaysTryHigherTieredLicense    string    "Layout L,Layout XL,"
    Aram
    I think the purpose of them was just to stop it asking you; the warning remains. You need the new cdsenv vars to stop it even looking for the lower tier licenses, and hence preventing the warnings.
    There is a workaround using $CDS_LICFLTR (I think there are solutions about this) which allows you to specify a script to deny access to licenses on the client side, but that's really overkill just to remove a few warnings. Better to move to the later ISR.
  • Aramsh
    Corect, I need to stop preventing even looking into license. And actually I don't care about warnings in
    CIW window, so if $CDS_LICFLTR just helps to skip warning messages, that does not help at this point....
    Aram
    If you have slow license access (due to a remote license server) then $CDS_LICFLTR could help, because it means that you can allow or deny the license locally, before it even tries to talk to the license server. Better is the ISR15 onwards feature.
  • Aramsh
    Yes, we have remote license server. I have read the manual for CSD_LICFLTR, but it's not pretty obvious how to use it.
    What's the values for that variable, if I want to filter e.g L and XL features?
    Aram
    Hi Aram,
    Create a script, say called "licfilter.ksh" something like the following:
    #!/bin/ksh
    #echo "Request to checkout $@"
    case $1 in
        Virtuoso_Layout_Suite_L) exit 1;;
        Virtuoso_Layout_Suite_XL) exit 1;;
      esac;
    exit 0
    Make the script executable, and then do:
    setenv CDS_LICFLTR /path/to/licfilter.ksh
    Then start virtuoso.
  • Aramsh
    Thanks for the script. Actually we use tcsh, but I will try to modify it!
     Best Regards,
    Aram
