  3. Flattening an imported GDS in Virtuoso
  • Views 16664
Verix
Verix over 16 years ago
I've managed to import a GDS file in virtuoso to a new library, while referencing other libraries. In other words, the GDS file contains references to cells in other libraries, so I selected these reference libraries in the import options. Everything went well, except when I try to flatten the newly created layout, the cells won't flatten. I found a workaround where I copy the referenced cells from the needed libraries, to the newly created library to which the GDS was imported, and then perform a flatten operation, and all will work fine. But do I always have to copy these cells? A copy doesn't always work, many times it gives a 'conflicting technology' error. I appreciate any attempt to help. Thanks for reading.
  • Quek
    Quek over 16 years ago
    Hi Verix
    You should be able to flatten an imported layout just as how you can flatten the original layout. No special steps are needed. Are there any warning/error messges in the ciw when you try to flatten the imported layout?
    Best regards
    Quek
  • Verix
    Alright I got it to work. I had to attach the library created after the import to a certain technology library. The problem was that this library was created as a technology library, and I had to delete the tech.db file inside the library directory so that it becomes a design library, then attach it to the appropriate technology library. Thanks a lot for the reply, I really appreciate it.
