  3. error closing tranViolations.violations during long sim...
  • Subscribers 133
  • Views 15660
error closing tranViolations.violations during long simulation
tkhan
tkhan over 16 years ago
I have a long simulation running (100us) with about 1000 bsim4 devices, and when the size of tranViolations.violations reaches 2Gb the simuation halts saying the file size has exceeded the maximum. From what I gather this file has some relation with assert statements (which I am not familiar with), and my PDK's models generate asserts for voltage warnings. If I disable the asserts in the model file, will I still have this problem? Is there any other workaround? I'm using IC6.1.3.500.16 and spectre 7.1.1.071.
  • sunilm
    sunilm over 16 years ago
    Hi ,
    tranViolations.violations file is created when we have the assert statements.
    Its a known issue in older release , when this file exceeds 2 GB limit , it just errors out.
    This issue is fixed in 711ISR9.  In this version and later, if the violation file size reaches 2Gig,
    instead of terminating the simulation, spectre will issue a warning message and no assert/checklimit data
    will be written from that point on.
    Please move to the latest ISR of MMSIM72 or as a workaround disable the device checks if you don't want them.
    We have one online solution for this case also :
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11585774
    Best Regards,
    Sunil
  • tkhan
    Thanks for the quick reply Sunil. I've disabled the asserts in my model file. I have been advised by my foundry to wait until they release the next kit patch before upgrading the tools, which should be in a week or so.
    Tarek
