  3. Layout: area of an instance
  • Views 17288
simbamford
simbamford over 16 years ago
 When I instance in layout a cell which I've previously laid out, and use the outline mode (i.e. Ctrl + f), I'd like to be able to control the size of the boxes that appear. The boundary doesn't seem to correspond to any of the boundary layers that you can draw but rather seems to be set simply as the minimal rectangle which contains everything drawn. The reason that I'd like to do this is that I've been designing cells where text that labels the inputs and outputs hangs off the edges of the actual layout (I don't know if this is against some unwritten rule, but to me it seems clearer. Is it possible to use one of the drawn boundaries to control the size of the cell for displaying and selecting it when it is instanced?
Sim Bamford
  • dmay
    dmay over 16 years ago
    You can draw a rectangle on the "instance drawing" layer purpose. However, I am not a big fan of this approach since you have to maintain the size of this rectangle. On occasion you can run into a case where the rectangle on this layer is very small relative to the cell extents and therefore it makes it harder to select the instance. Your best bet is to change the orientation or justification of your text to be inside your cell bounding box.
    Derek
  • simbamford
     Thankyou :)
