  3. Ploting schematic without showing component parameters
  • Replies 12
  • Subscribers 138
  • Views 28108
rickrevolta
rickrevolta over 16 years ago
Hello everybody
 I´m trying to plot my schematic at virtuoso schematic editor but I don not want to plot the component parameters. This is a plot for documentation purposes and it get a little confuse to see with a lot of infomation right next each transistor. How can I take off the component parameters  to plot the schematic ?
thanks
rickrevolta
    Andrew Beckett over 6 years ago in reply to BaaB +1
    Please don't post on 10 year old threads (see the Forum Guidelines). The old, horrible, Edit->Component Display form was replaced in IC616 with View->Annotations->Setup, which fixes most of the problems…
  • skillUser
    skillUser over 16 years ago
     Hi Rick,
    You can load the SKILL code from Solution 11131226 and then try the following to "turn off" all the instance labels:
    foreach(inst
      geGetEditCellView()~>instances
      CCSselectAllInstLabels(inst)~>isVisible=nil
    Hopefully this will do what you want - you can set the "isVisible" attribute to 't' to make them all visible again, or close the cellview without saving; next time it opens it should display all the labels again.
    Lawrence.
    You should also be able to do this without SKILL.
    In your schematic, do Edit->Component Display. Pick on one of the components, and on the form select "Select Label:" to be "parameter".
    Then in the Parameter Labels section, set the "Apply to: " to be "library", and then set the row below that to "none". If that doesn't work, set the "Apply to:" to be "cell", and then set it to none. In this case, you'll need to click once on each type of component. Whether it works for the library or cell depends on how the CDF has been setup.
    The easiest way to get everything back to normal is to do a File->Refresh in the CIW and OK the CDF refresh form that appears.
    You can also turn of terminal and instance labels using the same kind of approach.
  • rickrevolta
    Hello
    I want to thank you two guys, both ways works .The skill command has the advantage that you do it only once. I hope not to be asking a lot, but is there a skill command  to turn off the terminal labels too ?
    thanks again
    rick
    Rick,
    In the solution code that Lawrence referenced, change this part of the code:
             foreach(mapcar label setof(x obj~>master~>shapes
                            and(x~>objType=="label"
                                rexMatchp("cdsParam" x~>theLabel)))
    to:
                                rexMatchp("cdsParam" x~>theLabel) ||
                                rexMatchp("cdsTerm" x~>theLabel)
    This will pick up both the cdsParam and cdsTerm type labels.
  • Magistus
    Magistus over 11 years ago
    I have the same question, but none of the code works. Maybe the commands are changed since 2010? I am using Virtuoso 6.1.6. In the View-Menu I found ways to hide some of the text (i. e. "Hide Instance Labels") but I find no way to hide the Instance Names.
    Do someone have an idea?
    Thank you!
    For some reason the instance name (cdsName()) labels are not toggled. This is easily solved using this SKILL function - just call CCFtoggleInstName() to toggle or on off the display of those labels. Put this code in your .cdsinit and then stick the "CCFtoggleInstName()" on a bindkey maybe:
    procedure(CCFtoggleInstName(@optional (win hiGetCurrentWindow()))
      let((lpp)
        lpp=techGetLP(techGetTechFile(geGetEditCellView(win)) '("annotate" "drawing7"))
        lpp->visible=!lpp->visible
        hiRedraw(win)
  • Magistus
    Perfect, it works! Thank you Andrew!
  • david jk
    david jk over 6 years ago
    Hi Guys,
    Is there any way that the foreach loop Rick suggested I bind to a key and toggle with the key the visibility on and off? Is there also a way also to remove cell name labels, and the labels on the nets?
    Thx,
    David
    Andrew Beckett over 6 years ago in reply to david jk
    Not sure I quite understand the question David (and by the way, posting on the end of a 10 year old thread is not a good idea, as per the forum guidelines), but maybe this code will do what you want?
    /* abToggleLabelsForPlotting.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Apr 29, 2020
    Modified
    By
    Function to simply toggle label visibility on or off
    SCCS Info: @(#) abToggleLabelsForPlotting.il 04/29/20.18:30:39 1.1
    *    abToggleLabelsForPlotting([?win winId] [?instLabels t]     *
    *          [?termLabels t] [?wireLabels t] [?notes t]           *
    *     Toggles labels on or off for plotting. By default all     *
    * label types are toggled but you can control them individually *
    * with the keyword arguments. Note that the current visibility  *
    *        is determined from the first layer it looks at         *
    procedure(abToggleLabelsForPlotting(@key
        (instLabels t)
        (termLabels t)
        (wireLabels t)
        (notes t)
      let((lpps first lppId visibility cvId techId)
        lpps=`(
          ,@(instLabels &&
              ("device" "annotate")
              ("annotate" "drawing")
          ,@(notes &&
              ("text" "drawing")
              ("text" "drawing1")
          ,@(termLabels &&
              ("annotate" "drawing8")
          ,@(wireLabels &&
              ("wire" "label")
        first=car(lpps)
        cvId=geGetEditCellView(win)
        techId=techGetTechFile(cvId)
        lppId=techGetLP(techId first)
        visibility=!lppId~>visible
        foreach(lpp lpps
          lppId=techGetLP(techId lpp)
          lppId~>visible=visibility
        hiRedraw(win)
        visibility
  • david jk
    david jk over 6 years ago in reply to Andrew Beckett
    HI Andrew,
    Thx a lot for the prompt reply. I am pretty new here so sorry for breaking the rules...
    The code you sent is exactly what I need, or what I mean from here I can figure out myself what I need...:)
    Cheers,
    David
