  3. You are trying to run a CDB executable on an OA library...
  • Subscribers 136
  • Views 12320
You are trying to run a CDB executable on an OA library file 'symbol.oa'. You must run an OA executable to use that library file. How to solve?
800228
800228 over 16 years ago
 I have just installed the TSMC0.13um PDK (version: T-013-MM-SP-001-K3_1.3B). Our system uses cadence IC5141
After that, when I try to open a symbol of any components in tsmc013 library, following warnings appears:
*WARNING* ddMapGetFileViewType: You are trying to run a CDB executable on an OA library file 'symbol.oa'. The file is in library 'tsmc13rf' in cell 'rfnmos1v' in view 'symbol'. You must run an OA executable to use that library file.
I dont know how to solve the problem.
Guide me please. Thanks you.
  • 800228
    I have learnt that tscm013 version T-013-MM-SP-001-K3_1.3B uses OA database.
    While IC5141 is only supported CDB database. That is why it cannot open any symbol view in the above library.
    Do you know any solution for this issue?
    Or I have to install a older version of TSMC013 that bases on CDB database?
    By the way, I have received following list of documents from TSMC for TSMC013:
    0.13 micron mixed-signal (CR013G 1P8M FSG IMD) (12 documents)
    01. T-013-CM-SP-002 , Rev. 1.3, 0.13 UM CMOS MIXED SIGNAL RF GENERAL PURPOSE 1P8M SALICIDE 1.2&3.3V CU FSG SPICE MODEL 013G [22-OCT-2008; 33161k bytes]
     02. T-013-MM-PC-001 , Rev. 2.1, 0.13UM MIXED SIGNAL/RF 1P8M SALICIDE PCM SPEC, 1.2V/2.5V (and others) [06-FEB-2007; 108k bytes]
    03. T-013-MM-SP-001 , Rev. 1.4, 0.13 UM MIXED SIGNAL 1P8M SALICIDE 1.2V/2.5V RF SPICE MODEL (CR013G) [20-MAY-2009; 34966k bytes]
    04. T-013-MM-SP-001-B1 , Rev. 1.3A, 0.13UM MIXED SIGNAL/RF 1P8M SALICIDE 1.2V/2.5V RC (STAR-RCXT) TECH FILE [25-MAY-2006; 105M bytes]
    05. T-013-MM-SP-001-C1 , Rev. 1.3D, 0.13 UM MIXED-SIGNAL 1P8M SALICIDE 1.2V/2.5V RF LVS (CALIBRE) COMMAND FILE [13-OCT-2008; 1788k bytes]
    06. T-013-MM-SP-001-E1 , Rev. 1.3C, 0.13 UM MIXED-SIGNAL 1P8M SALICIDE 1.2V/2.5V RF LVS (HERCULES) COMMAND FILE [16-OCT-2008; 1263k bytes]
    07. T-013-MM-SP-001-K1 , Rev. 1.3B, 0.13 UM MIXED SIGNAL/RF 1P8M SALICIDE FSG PDK, 1.2V/2.5V (and others) [24-JUL-2007; 384M bytes]
    08. T-013-MM-SP-001-K3 , Rev. 1.3B, 0.13 UM RF 1P8M SALICIDE 1.2V/2.5V/3.3V 1P8M FSG PDK (CR013G)(CADENCE OA6.1 VERSION) [08-AUG-2008; 368M bytes] .
    09. T-013-MM-SP-001-T1 , Rev. 1.3A, 0.13UM MIXED SIGNAL 1P8M SALICIDE 1.2V/2.5V RF PDK (MENTOR GRAPHICS) [14-NOV-2006; 1974k bytes]
    10. T-013-MM-SP-001-U1 , Rev. 1.4A, 0.13 UM MIXED-SIGNAL 1P8M SALICIDE 1.2V/2.5V RF LVS (ASSURA) COMMAND FILE [31-AUG-2009; 1686k bytes]
    11. T-013-MM-SP-001-V1 , Rev. 1.3A, 0.13UM MIXED SIGNAL/RF 1P8M SALICIDE 1.2V/2.5V RC (ASSURA) TECH FILE [25-MAY-2006; 219M bytes]
    12. T-013-MM-SP-001-X1 , Rev. 1.3A, 0.13UM MIXED SIGNAL/RF 1P8M SALICIDE 1.2V/2.5V RC (XCALIBRE) TECH FILE [09-MAY-2006; 2205k bytes]
    What version should I choose for our application on IC5141 with ASSURA (Our main IC is a TIA with 3-dB bandwidth of 500MHz).
    (I have installed the PDK from document 08)
    Thanks you and best regards.
  • Marc Heise
    Marc Heise over 16 years ago
     Hello 80022,
    you have two options:
     A)  You install a OA based IC release ( I recommend 6.1.3 or 6.1.4)
    or
    B) You check if there is a cdb version of that TSMC kit you can run with IC5.1.41
    Marc
  • berndf
    berndf over 16 years ago
    If you have chossen 1.2V/2.5V process option you should use the following documents, command rule files
    for Assura
    -  T-013-MM-SP-001-U1for LVS
    -  T-013-MM-SP-001-V1 for parasitic extraction
     But you should cross check this with TSMC.
    The command rule files should be included in the TSMC PDK as far as I remeber.
    Bernd
  • tkhan
    tkhan over 16 years ago
    You have both OA and CDB PDKs, install whichever one you are more comforable with. I've noticed that K1=CDB, K3=OA with other TSMC kits.
