  3. about the corner analysis
  • Views 15101
minci
minci over 16 years ago
 hi,there
I am working with IC5141 USR6 add MMSIM72.
I want to know the relationship between the  configuraton in the option "Setup -> Model Library" and the scs file concluded in the PCF or DCF file loaded into the corner window.Do they have the same effect on the simulation? And if I want to run a corner analysis,should I setup the model library in the ADE,or just configure the corner analysis window instead?
minci
  • Quek
    Quek over 16 years ago
    Hi minci
    The model file settings in the corner tool will be used so the model file settings in the main ADE window do not matter.
    Best regards
    Quek
