  3. QRC + command file
  • Replies 9
  • Views 21684
QRC + command file
Slawa
Slawa over 16 years ago
Good afternoon dear colleagues.
I had a following problem.
I have started to master QRC but I can not adjust command file in any way. In particular I can not understand with -technology_library_file and -technology_name. Constantly writes "Could not map technology name "LALA" to a path using "/./XXX"Check spelling to insure the name is correct."   I have created a separate folder "techgen" in which have made simulation Techgen -si and Techgen -compilation. In it has put ict, proc, p2lvs, lvsrule, and qrcTechFile. And here to start QRC does not leave. What it is necessary to enter in a  -technology_name and -technology_library_file ? Very much I count on your help.
Best regards
Beginner engineer from Russia
  • tkhan
    tkhan over 16 years ago
    I haven't used command line QRC, but have you tried running QRC from Virtuoso Layout XL, filling in the desired fields in the GUI, running QRC extraction and seeing what the command line arguments are in the log file? That may give you some idea about what you're doing incorrectly.
  • Quek
    Quek over 16 years ago
    Hi Slawa
    You can resolve the problem as follows:
    a. Create a file named "qrc_tech.lib" in the working directory. It should contain this line:
    DEFINE LALA /your-path/yourTechgenDirectory
    b. In your QRC cmd file, you should have lines similar:
    process_technology \
       -technology_library_file "qrc_tech.lib"
       -technology_name "LALA"
    QRC will first look for the library definition file "qrc_tech.lib". If found, it will search for a library definition named "LALA". This should point to a directory which contains the file named "qrcTechFile". The library definition file does not really have to be named as "qrc_tech.lib". It can be any other filename.
    Best regards
    Quek
  • Slawa
     With it like clear. Did similarly. I can not understand whence to take "LALA". I so understand that QRC will search for this most "LALA" in qrcTechFile located on the address specified in "qrc_tech.lib" a file defined through "DEFINE". And as qrcTechFile it is received directly from ICT, accordingly "LALA" this name of technology specified in ICT a file? Or what?
    Best regards
  • Quek
    Hi Slawa
    The name usually follows the contents of the qrc technology directory. E.g. it can be "tsmc035", "umc90n", etc. It can be anything as long as the path is correct. It can be any "ABC" or "XYZ". It does not matter to qrc. The name is given according to the preference of the user.
    Best regards
    Quek
  • Slawa
     Thanks for the help. I did all correctly but a problem it has appeared in other. As well as cds.lib the file qrc_tech.lib has similar syntax and consequently problems with them identical. In this case after "DEFINE lala/path/lala"
    The cursor has not been rearranged for other line and QRC did not understand the termination of the given way. It is insulting that any more once came across on it with cds.lib at its clearing of remote libraries and has got again but already with QRC :)
    Best regards
  • Slawa
     Good afternoon dear colleagues. Allow to set to you some more questions on command_file for QRC.
    Now I study start QRC with Calibre input. Questions the following:
    1)-layer_map_file - maps the layers in the AGDS file to layers found in the Calibre
    LVS rules file. What its syntax? And if it is possible with an example.
    2) - library_cell_list_file, hierarchy_delimiter and design_cell_name....... Whether Is these parametres obligatory or they can be ignored?
    3) whether Prompt it is correctly made command_file for start with Calibre input and if there is no that that in it incorrectly? process_technology \
    -technology_library_file "qrc_tech.lib" \
     output_setup \
    -net_name_space layout \
    -directory_name /Any directory for storage of the output data
     extraction_setup \
    -technology_layer_map \
    M1 M1 \
    M2 M2 \
    M3 M3 \
    M4 M4 \
    M5 M5 \
    V1 V1 \
    V2 V2 \
    V3 V3 \
    V4 V4 \
    V5 V5 \
    GP GP \
    PolyCont CON \
    -max_fracture_length 50
     input_db -type calibre \
    -directory_name /path to a directory with the target data calibre query
    -run_name Design \
    -layer_map_file /path to a map_file.txt \
    -device_property_value 7 \
    -instance_property_value 6 \
    -net_property_value 5
     -design_cell_name AA01D1 layout LOGIC      ??? Whether it is necessary? And if yes that leaves that given library Cadence should be in the same folder whence all start QRC is made?
    output_db \
    -type spef \
    -subtype standard
     extract \
    -selection all \
    -type rc_decoupled
    graybox \
    -type none
    log_file \
    -file_name qrc.log \
    -dump_options true
    filter_coupling_cap \
    -coupling_cap_threshold_relative 0.05
    metal_fill \
    -type floating
    Best regards
  • Quek
    Hi Slawa
    The gds layer map file should be automatically generated during the Calibre query step and not manually created. The actual Calibre lvs database cannot be used directly by QRC. An additional "query" step has to be performed. Here is an example of its contents:
    Gds_Map 1000
    Layers:
    0 0 31 Oct  1 14:24:51 2007
    DNW 1 0
    nw_dnw 2 0
    The "library_cell_list_file" is needed when you are generated dspf or spef output. Otherwise, it is not required. "design_cell_name" is only needed if you are generated extracted view output. Otherwise, it is not needed. It is also not required to specify the hierarchy delimiter is the default value of "/" is fine.
    You do not to have "technology_layer_map" section if you are using Calibre input. It is only for LEF/DEF inputs.
    Best regards
    Quek
  • Slawa
     Many thanks for fast and the main thing the intelligible answer. Then we will return to "library_cell_list_file". What its syntax? And if I will tell I have project PROJECT containing LOGIC1 LOGIC2 IP1 IP2 PAD1 PAD2 that "library_cell_list_file" should contain them? Or this parametre concerns what that still? And with what the similar error can be connected?
    WARNING (RCXSPIC-28051): Substrate stamping disabled for X-DSPF/SPEF.
    WARNING (RCXSPIC-28131): The SPEF language as per IEEE 1481-1999 does not have a
     syntax for printing parasitic resistor or capacitor model names
    ERROR (LBMISC-215480): at "RCXspice": LVS connectivity file  is missing .2.
    ERROR (LBRCXM-633): Bad return status from RCX script generator. Status 512
    INFO (LBRCXM-709): *****  QRC terminated abnormally  *****
    Best regards
  • Quek
    Hi Slawa
    The format for "library_cell_list_file" is as follows:
    DEFINE myLib1 /abc1/xyz1/myLib1
    DEFINE myLib2 /abc2/xyz2/myLib2
    Do you mean that you have a project directory that contains the libraries "LOGIC1", "LOGIC2", etc? If the cells in these libraries are used in the design, then you have to declare them in the library definitions file.
    Would you please start a new thread for the qrc error so that we don't mixed up the question on ccl cmd file and qrc errors?
    Quek
