  3. Anyone used EQN(..) in Virtuoso-ADE->Setup Outputs?
  • Views 1050
swdesigner
swdesigner over 16 years ago
I believe there is a way to make one Output depend on another Output. I don't know how though. In the past, someone mentioned something like EQN - similar to VAR("name").
Does anyone know how to do this?
  • Quek
    Quek over 16 years ago
    Hi swdesigner
    You can simply use the name of the previous output. E.g. If you have already defined an output using:
    ABC : some expression
    Your next output can be:
    XYZ : some expression - ABC
    Best regards
    Quek
    Note that Quek's suggestion only works in IC614 and later.
    It's possible in earlier releases to do this by doing:
    ABC: ABC=some_expression
    XYZ: some_other_expression-ABC
    i.e. you have to assign the result to a variable, and then you can reference that variable. The problem is that ADE doesn't understand the order dependency (until IC614, using the supported approach without the =), so you need to carefully enter your expressions such that the variables are defined before they're used (they're evaluated top to bottom in the ADE window). The order can't be changed from the UI (until IC614 when you can drag and drop them, although this isn't necessary for dependent expressions - it figures out the dependency order).
