  3. How to short small resistor for lvs purpose
  • Replies 7
  • Views 22368
harleyMax
harleyMax over 16 years ago
 h, i have a small resistoe which dracula lvs (version 4.8) used to short its 2 nodes, but, now i am using dracula version 4,9 and no longer short them in lvs. what options i have. i am using ic5.41.
Thanx a lot
max
    Max,
    Normally you need to have *.RESI in your CDL netlist to tell Dracula LVS to short resistors below a certain value. Do you have that?
    I'm not aware of this having changed.
  • harleyMax
    thanks for the reply, however, my circuit was lvs clean when i was using dracula 4.8. Now since, i am using 4.9 is no longer short the resistor. i found no matter how the value of RESI is, it just does not work. here is my header cards:
    *.BIPOLAR
    *.RESI = 0.005
    *.RESSIZE
    *.CAPVAL
    *.EQUATION
    *.LDD
    *.SCALE
    *.DIOAREA
    *.MEGA
    .PARAM
    something bugy in 4.9 dracula i think. BTW i am using IC5.41 and "lxRemoveDevice" property does not work for me.
    i use this on the resistor instance as follow:
     lxRemoveDevice
    Type: string
    Value: (SHORT(A B))
    Thanx,
    - Max
    Max,
    The problem is because you have *.RESSIZE in the netlist - it is therefore expecting the resistors to be defined by their size (dimensions) rather than by their value.
    If you have this line omitted, or have *.RESVAL in the netlist, it will then short resistors less than 0.005 ohms (I tested this in Dracula  4.9.03-2010).
    Note that using lxRemoveDevice to do this is only supported in IC61 onwards - it needs changes in the netlister to not netlist the component, and do the shorting at netlisting time.
  • harleyMax
    thanks for the quick response,  i already tried "*.RESVAL" once i use "*.RESVAL" the RESI is not being into accounted, therefore, no matter how much RESI value is, dracula short the resistor and i do not want this.
    the CDF of my metal1 resistor shows L = 1nm, W = 400n, and shre/unitSq = 0.08ohm, so, the calculated value of the resistor = 200e-6ohm
    as i said dracula version 4.8 has no problem with it.
    for now to get around with this issue i am using "loglvs" with ver 4.8 and using "pdracula" with ver 4.9. this arrangement i get resistor shorted. i guess i looking for another permanent solutio, as you see i have to use *RESSIZE, since my resistor is defined as W&L.
    - Max
  • harleyMax
     hi andrew, can you try *RESSIZE instead, if that works, i will link my dracula to ver 4.9.03-2010.
    my resistor element is defined as w & l, so, i like to use *RESSIZE. btw do you know a way to short this resistor in netlist i am agian using 5.41?
    - max
    Max,
    It's rather hard to see how *.RESI could work if you're using *.RESSIZE, given that the ignore threshold is specified as a resistance, and if the CDL netlist just has widths and lengths, it wouldn't know the resistance (the sheet resistance would not be known to LOGLVS).
    In fact the documentation for *.RESI (ICinstDir/doc/dracularef/dracularef.pdf) says:
    You must also specify the *.RESVAL command when using the *.RESI command. However, do not specify the *.RESSIZE command when using the *.RESI command as it may result in unpredictable behavior.
    Maybe it worked in the older version due to the "unpredictable behavior" mentioned above - something that should not have been relied upon
    One other possibility would be to use a 0V source to short two nets in the CDL netlist. This is described in the LOGLVS chapter of the Dracula Reference manual mentioned above.
