  3. ASSURA LVS PROBLEM FOR AMI C5 PDK
  • Views 17916
CHECKMATE
CHECKMATE over 16 years ago
I designed a simple inverter circuit and was testing the new AMI C5 PDK I received from MOSIS.
I ran the design rule check using assura and it worked fine and ir gave me no DRC errors.
Then when I ran the LVS using assura. I added the correct extract file and the correct bind.rul file and ran the LVS and it works fine.My schematic and Layout matches.
 But when I ran the LVS using assura having added the correct extract file, the correct compare rule file and the correct bind.rul file.It gives me the following error:
"Error - netlisting (dfII "....") rule can not be used with other schematic netlist rules.
*ERROR* encountered while reading avCompareRules.
 *ERROR* Syntax errors in file '/home/jhasan/AMI_C5/LVS_RUN/TEST.rsf'
Note I am running it on ASSURA version 3.1
This is the compare.rul file I received from MOSIS for the AMI C5 PDK:
; avCompareRules (AMIS Technology Development)
; $AMI/tech/common/current/assura/compare.rul (AMIS)
; 03/26/2002 Updated BRD
; 04/20/2002  DAS  Fixed path to box.cdl
; 04/22/2002  BRD  Restored path to box.cdl
; 05/15/2002  BRD  noMerge series caps, merge parallel
; 07/08/2002  BRD  added back bind.rul
; 09/05/2002  BRD  added swapPins for caps
; 09/13/2002  BRD  added filterDevices for presistor and pcapacitor
;                  to filter from schematics
; 10/16/2002  BRD  Set bind.rul path from beta to current
; 11/06/2002  BRD  added ls,ml,om,qo swapPins
; 12/18/2002  BRD  changed compare percents to 0.5 from 0.005
;                  added pdiode filter
; 01/08/2003  DBM  Jake tested the changes to follow.
;           added cdl versions of pdiode and pcap
;           added commented out versions of a filter
;           statment and bindfile as well as the
;           listXRef() and upped the autoPinSwap().
avCompareRules(
schematic( netlist( cdl strcat(getShellEnvVar("AMI") "/tech/ami500hakx/current/cdl/box.cdl" ) )
   swapPins("pp" nil)
   swapPins("cn" nil)
   swapPins("cp" nil)
   swapPins("ls" nil)
   swapPins("ml" nil)
   swapPins("om" nil)
   swapPins("qo" nil)
   genericDevice("cnvar")
   genericDevice("dschottky")
   genericDevice("esq")
   genericDevice("thru")
   genericDevice("ext")
   genericDevice("probe")
   genericDevice("v5")
   genericDevice("v12")
   genericDevice("v20")
   genericDevice("v40")
   filterDevice("presistor" short("PLUS" "MINUS"))
   filterDevice("pcapacitor")
   filterDevice("pdiode")
   filterDevice("CP")
   filterDevice("DP")
  mergeSplitGate( sameOrder )
  mergeParallel( MOS merge )
  mergeParallel( RES merge )
  mergeParallel( CAP merge )
  mergeParallel( BJT merge )
  mergeParallel( LDD merge )
  mergeSeries( MOS merge )
  mergeSeries( BJT noMerge )
;  mergeSeries( RES noMerge )
  mergeSeries( RES merge )
  mergeSeries( CAP noMerge )
  mergeSeries( LDD merge )
  compareParameter( MOS percent( "w" 0.05 "l" 0.05 ) )
  compareParameter( RES percent( "VALUE" 0.05 ) )
  compareParameter( BJT percent( "EA" 0.05 ) )
  compareParameter( CAP percent( "VALUE" 0.05 ) )
  compareParameter( LDD percent( "w" 0.05 "l" 0.05 ) )
  listXRef()
  listFilteredDevices()
  filterReduceStatistics()
  formGate(none)
  autoPinSwap( t 1000000)
  bindingFile( strcat(getShellEnvVar("AMI") "/tech/ami500hakx/current/assura/bind.rul" ))
;  filter( "BCOFGPX")
;  bindingFile( "lvs.bind")
) ; end of avCompareRules (AMIS Technology Development)
Please let me know how I can solve this bug in assura.
  • Quek
    Quek over 16 years ago
    Hi checkmate
    When running using DFII schematics, we cannot have both "dfII" and "cdl" inputs in the avCompareRules section. If you check your rsf file using the "View rsf" button on the lvs form, you should be able to find something similar to:
    avCompareRules(
       schematic( cdl ".../box.cdl")
    avCompareRules(
       schematic( dfII ".../yourDesign.vlr")
    Your current files are good for running Assura using cdl/verilog inputs. Here is how you can resolve the problem:
    a. Comment out the line in following line in compare rules using a semi-colon. E.g.
    ;schematic( netlist( cdl strcat(getShellEnvVar("AMI") "/tech/ami500hakx/current/cdl/box.cdl" ) )
    b. In the lvs form, press the "Netlisting Options" button. A form appears, at the end of the form, there is a field for adding cdl netlists. Please add "box.cdl" file using this form.
    c. Now run lvs. It should be ok now. If you examine the "design.vlr" file in the run directory, you should see something similar:
    avSimName = "auLvs"
    avDisableWildcardPG = nil
    avLibName  = "myLib"
    avCellName = "myDesign"
    avViewName = "schematic"
    avViewList = "auLvs schematic symbol"
    avStopList = "auLvs"
    avVldbFile = "/myPath/avLVS/myDesign.sdb"
    avReadCDL( "/myPath/box.cdl" )
    By the way, if it is possible, please upgrade to the latest version of Assura. Assura31 is too out-dated. : )
    Best regards
    Quek
  • CHECKMATE
     Hello Quek,
    I am little bit confused!
     When you mentioned that "Comment out the line in following line  in compare rules using a semi-colon."
     So, this is my new compare.rul file:
    avCompareRules(
    ;schematic( netlist( cdl strcat(getShellEnvVar("AMIS") "/ami500hakx/Rev6.17/cdl/box.cdl" ) )
    ;   swapPins("pp" nil)
    ;   swapPins("cn" nil)
    ;   swapPins("cp" nil)
    ;   swapPins("ls" nil)
    ;   swapPins("ml" nil)
    ;   swapPins("om" nil)
    ;   swapPins("qo" nil)
    ;   genericDevice("cnvar")
    ;   genericDevice("dschottky")
    ;   genericDevice("esq")
    ;   genericDevice("thru")
    ;   genericDevice("ext")
    ;   genericDevice("probe")
    ;   genericDevice("v5")
    ;   genericDevice("v12")
    ;   genericDevice("v20")
    ;   genericDevice("v40")
    ;   filterDevice("presistor" short("PLUS" "MINUS"))
    ;   filterDevice("pcapacitor")
    ;   filterDevice("pdiode")
    ;   filterDevice("CP")
    ;   filterDevice("DP")
    ;  mergeSplitGate( sameOrder )
    ;  mergeParallel( MOS merge )
    ;  mergeParallel( RES merge )
    ;  mergeParallel( CAP merge )
    ;  mergeParallel( BJT merge )
    ;  mergeParallel( LDD merge )
    ;  mergeSeries( MOS merge )
    ;  mergeSeries( BJT noMerge )
    ;  mergeSeries( RES merge )
    ;  mergeSeries( CAP noMerge )
    ;  mergeSeries( LDD merge )
    ;  compareParameter( MOS percent( "w" 0.05 "l" 0.05 ) )
    ;  compareParameter( RES percent( "VALUE" 0.05 ) )
    ;  compareParameter( BJT percent( "EA" 0.05 ) )
    ;  compareParameter( CAP percent( "VALUE" 0.05 ) )
    ;  compareParameter( LDD percent( "w" 0.05 "l" 0.05 ) )
    ;  listXRef()
    ;  listFilteredDevices()
    ;  filterReduceStatistics()
    ;  formGate(none)
    ; autoPinSwap( t 1000000)
    ;  bindingFile( strcat(getShellEnvVar("AMIS") "/ami500hakx/Rev6.17/assura/bind.rul" ))
    So,  basically commented out everything except the avCompareRules line in compare.rul.
    I also added the cdl netlisting in the Netlisting Option window.
    Then when I ran the LVS, then it works fine.
     I just want to double check is that you wanted me to do.
    Or did you want me to  just comment out the "schematic (netlisting(cdl strcat(getShellEnvVar("AMI")"/tech/ami500hakx/current/cdl/box.cdl"))" line and leave the others uncommented.I tried that but then LVS gives me errors.
     Please let me know.
  • Quek
    Hi checkmate
    Yes, I meant only to comment out the line containing box.cdl. May I know more about the new erros which you have encountered?
    Best regards
    Quek
  • CHECKMATE
     IF I only comment out this line in compare.rul file.
    ;schematic( netlist(cdl strcat(getShellEnVar("AMIS") "/ami500hakx/Rev6.17/cdl.boc.cdl"))
    I get the following errors:
    *Error* eval: undefined function -  mergeSplitGate
    *Error* load: error while loading file - "/home/jhasan/MAI_C5/LVS_RUN/TEST.rsf"
    *Error* load: error whule loading file - "*loadstring*"
    Errors exist in master control file "home/jhasan/AMI_C5/LVS_RUN/TEST.rsf".
    Also, I am attaching my TEST.rsf file.
    Please let me know.
    • TEST.rsf.txt
  • Quek
    Hi checkmate
    Sorry that I made a mistake in my previous mails. We should not comment out the entire line, only the "netlist..." part. So it should be:
    schematic( ; netlist(cdl strcat(getShellEnVar("AMIS") "/ami500hakx/Rev6.17/cdl.boc.cdl"))
    Best regards
    Quek
  • CHECKMATE
    Yes, LVS is finally working after the changes you suggested in your last e-mail.
