  3. Module instantiation using Generate statement
  • Views 18472
write2rammy
write2rammy over 16 years ago
Hi all,
     I am using a generate statement to instantiate a delay module (cur_starved_delay) 11 times. The basic idea is to model a 11 stage ring oscillator using current starved delay cell. But i get syntax error in generate statement. Can anyone help me with this. The code is attached below.
module multiphase_vco(Vbias_p,Vbias_n,Vdd,Vss, out);
parameter integer NO_STAGE  = 11;
parameter real C_load = 1e-12;
parameter real Kp = 1;
parameter real Kn = 1;
parameter real Vt = 0.2;
parameter real pos_tol = 0.2;
parameter real neg_tol = -0.2;
genvar i;
input Vbias_p,Vbias_n,Vdd,Vss;
output [11-1:0] out;
voltage Vbias_p,Vbias_n,Vdd,Vss;
electrical [NO_STAGE-1:0] out;
real ph_out[NO_STAGE-1:0];
generate
    for (i =1;i<=11;i=i+1) begin
          cur_starved_delay #(.C_load(C_load),.Kp(Kp),.Kn(Kn),.Vt(Vt),.pos_tol(pos_tol),.neg_tol(neg_tol))
                 D_i(.Vin(ph_out[i-1]),.Vbias_p(Vbias_p),.Vbias_n(Vbias_n),.Vdd(Vdd),.Vss(Vss),.Vout(ph_out[i]));
    end
endgenerate
ph_out[0] = ph_out[NO_STAGE]);
@(initial_step) begin
    ph_out[0] = V(Vss);
end
end
endmodule
  • write2rammy
     Please ignore the extra end statement after initial_step block
    In fact it's not just the end statement that's wrong. The whole:
        ph_out[0] = V(Vss);
    end
    end
    is wrong. The first line has got an extra close parenthesis. It probably needs to be inside an @(initial_step) block, or similar, in which case it's superflous. Also, these need to be inside an analog block.
    Next is that the D_i instance appears to be connecting to a real array, rather than a voltage array.
    Finally is the main issue, that assuming that cur_starved_delay is an analog module (you didn't give the details), this is not supported in AMS. If I omitted the lines above, it compiles OK with no errors, but during elaboration I get:
    ncelab: *E,VHANAG (./gencode.v,38|19): Module "cur_starved_delay" has analog element(s) in it. Instance multiphase_vco.genblk1[11].D_i of this module is not yet supported inside generate statement.
    voltage Vin,Vbias_p,Vbias_n,Vdd,Vss,Vout;
    ncelab: *E,VGDADS (./gencode.v,6|10): multiphase_vco.genblk1[11].D_i.Vin has got declared analog discipline "voltage". Use of analog element inside Generate statement is not yet supported.
    and many such errors. If I expand these errors with nchelp I get:
    UNIX18> nchelp ncelab VHANAG
    nchelp: 09.20-s020: (c) Copyright 1995-2010 Cadence Design Systems, Inc.
    ncelab/VHANAG =
            The module/architecture pointed out by this error message has analog element(s) inside it.
            Instantiation of this analog unit inside a Verilog or VHDL generate statement is not yet
            supported.
    UNIX19> nchelp ncelab VGDADS
    ncelab/VGDADS =
            The net pointed out by this error message is declared as analog. Use of this analog net
            inside a Verilog or VHDL generate statement is not yet supported.
    You will need to contact customer support and request an enhancement to support analog elements inside a generate statement. There is already a request for this, CCR 700708, but it's best if each customer requests it who needs it, then there's a fair reflection of the amount of demand, which helps in prioritization.
