  3. Options/Display - Shape information
  • Replies 17
  • Subscribers 136
  • Views 12704
Liahuro
Liahuro over 16 years ago
Hi Cadence Community, I have my first question in this forum. In IC5.1 there was an option to display shape information in the corner of the screen. This is a "Shape information" check-box. When we move cursor touch any object then at the corner of current window will show all information of shape as : Layer-Shape(rectangle, polygon,..) How can I make this thing with skill code? Please help me know. Thanks, Q
  • skillUser
    skillUser over 16 years ago
    Hi Liahuro,
    In order to implement something like this in SKILL you would need a triggering event, something like onMouseOver - but this does not exist in SKILL to my knowledge.  The best I think that you could do is to create a bindkey (a mouse click or key combination) and then use the mouse location to gather information about what's at the cursor.  The function hiGetCommandPoint() could be useful, as might gePointQuery().  With a coordinate point you might use something like dbGetOverlaps() or dbGetTrueOverlaps() to find what shapes are under that point.
    Hopefully this will help you.
    Lawrence.
    In IC61, go to Options->Dynamic Display, and turn on "Show Info Balloon". You may also want to ensure that everything is checked on the Setup tab. As you hover over instances, you'll get an info balloon appear. This is similar information to the old "Shape Information" option in Options->Display in IC5141, just implemented with a more modern UI (a transparent info balloon). There's also an icon in one of the toolbars (a light bulb) to toggle on or off the info balloon display (in IC613 and IC614).
  • Liahuro
    Dear Lawrence & Andrew Beckett, Thanks for your help. I can implement some functions to get all shapes & return the current locations of the pointer in cell view. But in order to display/show all property(layer/shape/...) at the corner of layout is not. Do you have any way to help me?. @Andrew : "modern UI (a transparent info balloon)", can you explain more clearly?. Regards, Liahuro
  • Liahuro
  • Liahuro
       Liahuro
    Sorry, my assumption was that you wanted to implement this in SKILL because you couldn't find it in IC61X. I was trying to save you the effort by showing you something similar (and better) in IC613/IC614. I don't know what version you're using, but if using these versions, I'd suggest you try it - I already explained how to enable it!
    If you're using IC5141, you already have it, so not sure why you need to write your own SKILL code.
    As Lawrence said, there's no way to do it with a "mouse over" because there's no event for that in SKILL. You could display info on selection, by using the leRegUserObjectSelectionFilter which allows you to register a trigger on selection.
  • dmay
    dmay over 16 years ago
    Take a look at this post for a different solution for when an object is selected (Info is displayed in the CIW upon selection):
    /forums/p/11732/15144.aspx#15144
    Also, there is a way to achieve a "mouseOver" effect in 5.1.41 using leRegUserObjectSelectionFilter. You have to be careful with this because it will call your registered routine constantly as you move your mouse. A short, very efficient piece of code is all that you should register with this routine. In this case, the code always returns t. However, you can configure it to return nil when you don't want a specific object to be selectable. I prefer the solution in the above post, but the following code is as close to a "mouseOver" feature as you are going to get in 5.1.41.
    _MOUSE_OVER_GLOBAL=nil
    procedure(myMouseOver(obj)
      prog((newString)
        sprintf(newString "ObjType: %L   Lpp: %L  CellName: %L\n" obj~>objType obj~>lpp obj~>cellName)
        unless(newString==_MOUSE_OVER_GLOBAL
            _MOUSE_OVER_GLOBAL=newString
            printf("%s" _MOUSE_OVER_GLOBAL)
        return(t)
      );prog
    );procedure
    leRegUserObjectSelectionFilter("myMouseOver")
    Then you can run this command to turn it off:
    leUnregUserObjectSelectionFilter()
    Derek
    Sorry, had a brain lapse. I suggested leRegUserObjectSelectionFilter in my last post but forgot (not sure why I forgot, because I've used it for this purpose myself) that it gets called before selection (this is so it knows whether to highlight the object you're over or not - i.e. if it's selectable).
  • Liahuro
    Dear Andrew,
      Actually, I want to build a application to help manual layout. As you know we use bind key  'q'  to show/edit property of the selected objects, It will take your time to press short key 'q',
    a repetitive job is very boring :((.
     I try to create a script can display all information of the selected objects when moving or clicking cursor touching boundary/bBox of these objects.
     No end obliged to you!
     @Derek :  You are a big help!
      I have a new problem wanna ask you. The function leZoomToSelSet() can zooms the selected objects to fit the window. But at top cell or instances, It's not work?
  • Liahuro
    If I want to zoom out/zoom in the selected objects to fit layout window (top cell or low level,....). Is there any way?
