  3. Export gds
  • Views 15285
Export gds
sathisha
sathisha over 15 years ago
Hi, I have layout with all the devices orientation is horizontal. is there any way to export the gds by rotating the whole layout? (so that the device orientaion will be vertical) i am using IC6.3v Thanks, Sathisha
  • StefanSL
    StefanSL over 15 years ago
     Hi Sathisha,
    the GDS2-format knows mainly cells and drawing elements; the hierarchy is
    built up by placing cells within a cell, the placing is described by the location,
    the orientation and the magnification of the subcell;
    What you would need, is a rotation of the whole layout, but there's no element
    above your topcell to define a rotation of the topcell.
    What about just creating a new TopCell and placing your layout into it, at 0/0, scale 1 and R90,
    and then streaming out the new TopCell?
    This should solve your problem;
    if this rotation is allowed with respect to anisotropic processes and devices is a different question...
    kind regards
    Stefan
  • sathisha
    Hi Stefan, Yes you are correct. I want to export the whole layout by rotating. I have so many cells, each time i need to create new cell rotate and verify, and again rotate it back to initial position. is there any script to do this. Thanks, Sathisha
