  3. leHiEditProp()
  • Views 15150
leHiEditProp()
Liahuro
Liahuro over 15 years ago
Dear, Is it possible to have a function like the leHiEditProp() in cadence by skill code? Is there anyone else who can help me? Regards, Liahuro
  • skillUser
    skillUser over 15 years ago
    Hi Liahuro,
    Yes, but it depends on the object that you are trying to change.  For example, if it is a PCell then you would modify the pcell instance parameters.  If it is a shape, then you can modify the shape's database attribute(s). For example:
      ;; modify a shape's layer
      car(geGetSelectedSet())~>layerName
      => "metal1"
      car(geGetSelectedSet())~>layerName = "metal2"
    An example of changing instance origins is given in this recent post
    You will probably need to supply more detail for your question to be answered in more detail.
    Lawrence.
  • Liahuro
    Hi Lawrence,
             Sorry, I'll describe this question more detail.
             I want to create a FORM like leHiEditProp() or leEditDesignProperties() func & How to get all information of input entered  :
             Example :
                     Menu : "Attribute"     include fields :  "layers" - METAL1, "leftEdge"- 0.0, "rightEdge"- 1.0, "topEdge" - 1.0, "bottomEdge" - 0.0
                     Menu : "Overlap"       inlclude fileds : "layers"-METAL1, "olapViaLeft - 0.01", "olapViaRight"-0.02, ....
                     Menu : "Spacing"      include fileds :  "Spacing in X"  - 0,5 , "Spacing in Y" = 0.8
              I myself have quite a limited knowledge in this area :((
    Thanks & Best Regards,
    Lia
