  3. IBM cms9flp & Assura QRC strange problem
  • Replies 13
  • Views 8417
jimito13
jimito13 over 15 years ago
Hello all,
I will try to describe my problem the better i can.I have an op-amp design that consists of several cells (main opamp,gain boosters,cmfb,biasing).I have created the layout of all the above cells and i pass successfully from DRC and LVS runs (clean runs,no errors no warnings).The last step is to perform the parasitics' extraction and run post layout simulations.Well,here things become a little bit strange...Before i describe my problem in depth i must say that my design kit is IBM's cms9flp and the versions of cadence virtuoso and assura are IC6.1.3.500.13 and 3.2_USR2_HF11 respectively.
I run LVS for each cell successfully (clean results) and then i run successfully as well the assura QRC run (no errors-no warnings) for all my cells and the result is the well known message of assura with the av_extracted view's name and location in the library.
Next step is to simulate the av_extracted views.For this i create a schematic with all the above cells interconnected as symbols and i use the av_extracted declaration under Environment submenu of ADE L.
I run DC analysis at first and here is my issue.The currents in all branches of the circuit are far away from the designed values.From a quick thought you can say that i made mistake in transistor sizes during layout but this should be reported by LVS but in any case i double checked this by myself to be absolutely certain.Second thought is that i have not calculated correct the widths of all metals that make the interconnections in the design,i double checked this as well according to pdk's rules for metals and viases.With a more careful view in the values of the currents that dc analysis resulted i noticed that all of them are divided by the product (m*nf),where m is multiplicity and nf number of fingers!Looking at the vdd symbol i see that my circuit consumes X mA but if i add all the currents from the subcells i do not ever reach X/4 mA,so i ask myself where is the rest of the current consumed?!Another strange thing is that even though that all currents are wrong calculated the biasing voltages from the current mirrors are exact to the design values...
Has anybody else come up with such an issue with this or another IBM's pdk??Do you think that i should report this straightly in IBM's support??
Thanks in advance for any helpful answer.
PS. It is urgent for me since tape out date is close!!
  • Quek
    Quek over 15 years ago
    Hi jimito
    If you simulate just a small cell (e.g. a current mirror block), do you have the same problem?
    Best regards
    Quek
  • jimito13
    Hello Quek,
    It seems that the circuit "burns" the desired value of total current (the same with the value i get when i simulate the schematic with the symbols not as av_extracted views but as schematic views) but when i add all currents "by hand" from all branches i am far away from this annotated value on the VDD symbol of schematics L.After some observation on the annotated values i noticed that the indicated current on the schematics L after the dc analysis is the current that flows into the one finger of a transistor even if it has multiplicity factor (bus more exactly) or not,that's why i wrote in my previous post that all values are divided by the product (m*nf).
    On the other hand,i simulated a test case with the main opamp only and biases from ideal sources and an ideal cmfb circuit that i have created and the problem still remains when av_extracted view is the simulated...
    Another colleague that works in my lab a few months ago had created a test case with a simple resistively loaded common source topology and we tested my problem on it and it was simulated correctly after the RC extraction.We just divided the transistor into 2 parallel fets with bus and some fingers and connected it with the resistor with metal1 just to make the test,not anything important from layout aspect!
    Do you suspect something that causes this strange problem or you think that IBM will give the answer?
    Thanks a lot in advance.
    Jimito13
  • Quek
    Hi Jimito
    Sorry for the late reply. Actually I think this looks like a setup issue that might has a reasonable explanation if there is a testcase. It would be good for your Prof to help contact Cadence or IBM support for this issue.
    Best regards
    Quek
  • jimito13
    Hello Quek,
    Well we contacted IBM and they admitted that there is an error while the total current is calculated when the av_extracted view is post simulated.They didn't give us any solution instead of proposing us to change all fets from my design to nfet_rf and pfet_rf (now i use the regular fets-nfet,pfet and the respective lvt versions)...Only in this case they said that the problem is solved...Anyway,this is the least annoying since if i multiply the multiplicity factor with the number of fingers and the simulation current i get the total correct current that i expected.So,i suppose that i am ok with it.But...
    There is another more difficult issue that hasn't been solved up to now even from IBM's support (they proposed me the same solution i wrote above for this issue as well !!).After simulating my opamp i notice severe voltage mismatches at various symmetrical branches (20mV the one and 700mV for example the other !!!).We checked the layout with my professor and he admitted as well that everything is ok and that those mismatches cannot be explained...We made all the checks (parasitic resistances,widh of interconnection cables,symmetries,distances etc...) that must be done and we didn't find any problem to my layout.My professor insists that i must change all fets to RF fets for a cell and post simulate it,if problem still exists then he says that we must report back to IBM.This is a little bit difficult to be done.Have you ever seen something like that happening during post simulation with a specific design kit and in this case what did you do to solve it??
     Thanks in advance,
     Best Regards,
    Jimito13
  • Quek
    Hi Jimito
    Just to be sure that those voltage mismatches are not due to a bad extracted view, you can try the following:
    a. In the terminal window, enter the following:
    terminal>setenv DBGRCX_CONNECTIVITY Y
    terminal>icfb &
    b. Run Assura LVS and QRC extraction to generate an rc extracted_view
    At the end of the extraction, there should be connectivity checking using gemini checker. This is to confirm that the netlist is still correct after insertion of rc parasitics.
    There are indeed some old cases in which we see bad simulation results due to broken nets in the extracted view. I think sending a testcase to IBM would be a good idea.
    Best regards
    Quek
  • jimito13
    Hello Quek,
    Thanks for your replies.I have a couple of question before i try your suggestions.
    1.Where the environment variable DBGRCX_CONNECTIVITY will be stored after the execution of the command  setenv DBGRCX_CONNECTIVITY Y via linux terminal?
    2.Will this command work with virtuoso instead of icfb,thus with command virtuoso &? (What is "&" after virtuoso?)
    3.What is gemini checker?Is a tool that comes with assura?
    We have sent a testcase to IBM's support and they are working on it,we still wait for their final response...They suggested me to try the LVS_extracted view and run "R only" and "C only" extraction runs.I did it and the problem happens only to R extraction...
    Sorry to ask so much questions but i want to go in-depth with the things i deal with :-)
    Thank you in advance.
    Best Regards,
    Jimito13
  • Quek
    Hi Jimito
    a. This is a shell variable. It will be active in the terminal window in which the command has been executed.
    b. Actually it is not a matter of whether the variable works with IC61 or IC51 because Virtuoso is not the tool that is using the variable. QRC is the tool. So it does not matter whether you use "virtuoso" or "icfb". The "&" is to send the process to the background. This means that Virtuoso can continue to run even if you accidentally close the terminal window. If you do not use "&", Virtuoso will crash if you close the terminal window
    c. Gemini is a connectivity checker that comes with EXT package. It used to come from Assura package.
    It is common to have problem for only r-only or rc-extraction and not for c-only extraction because the network is altered more when there is resistance fracturing. Using gemini saves you the simulation step. My guess is that if you try gemini with r-only extraction, you will get mismatch reported.
    There is no way to resolve gemini errors except to upgrade the version of QRC. I think it would be good if you can upgrade to the latest EXT913HF2.
    Best regards
    Quek
  • jimito13
    Hello Quek,
    Thanks again for your clear answers :-) . Well i did what you proposed me with gemini checker combined with R-only extraction and the result from QRC report is the following :
    # Verify netlist connectivity
    cat <<ENDCAT> gemfilterfile
    F model=C 2 X X
    ENDCAT
    gemini -V -S -sd -w -td 0.01 -flt gemfilterfile -ac"C" -prr_c '#' -f_name_io \
        s#vdbToRcx.sp s#/users/jimphd/Dimitris/ota_main/LVS/LVS/extview.tmp
    INFO (GEMINI-113014): gemini: Declaring node 0 as global - default.
    Removed parasitics in ota_main (resistors: 7855 -> 0, L-inductors: 0 -> 0, VCCS: 0 -> 0)
    THE DESCRIPTIONS MATCHED COMPLETELY, ota_main & ota_main
    GEMINI COMPARISON CONCLUDES:
    The circuits match completely.
    INFO (GEMINI-113292): Gemini: Reading files took
    INFO (GEMINI-113184):  0.08 user, 0.00 sys, 0.00 elapsed, 3526.7 Kbytes
    INFO (GEMINI-113293): Gemini: Comparison took
    INFO (GEMINI-113184):  0.01 user, 0.00 sys, 0.00 elapsed, 3813.4 Kbytes
    What can i conclude from the above statements?
    And a final question..if i put the setenv command i run before in my .cshrc file,i will be able to load gemini everytime i access assura,right?If not how can i have permanent access to gemini for every active assura session?
    Thanks a lot for your precious help.
    Best Regards,
    Jimito13
  • Quek
    Hi Jimito
    This seems quite strange. You mentioned that simulation using r-only extracted view gives wrong results but yet gemini is reporting that the extracted view is ok. Could it be that your circuit really has some problems after the addition of the resistors? Perhaps more checking is needed.
    You can put the cmd in your .cshrc file so that gemini is enabled automatically every time you run QRC.
    Best regards
    Quek
  • jimito13
    Hello Quek,
    To understand better..gemini checks only connectivity problems or something else additionaly in my layout during extraction procedure?e.g. does it check for parasitic resistor mismatch to symmetrical branches of a circuit,let's say drain net of nmos transistors in a differential input pair of an amplifier?
    You said that : Could it be that your circuit really has some problems after the addition of the resistors?
    Do you mean layout problems or testbench setup problems?
    Thanks a lot in advance :-)
    Best Regards,
    Jimito13
