  3. LVS error
  • Views 21782
LVS error
Sambhav
Sambhav over 15 years ago
I am designing a simple inverter. After I layout my inverter, i extract it using divaEXT.
And then when i run LVS (divaLVS) i get an error saying:
"The LVS job has failed to run to completion, Examine si.out and si.log in the run directory for more information"
The contents of the si.log file is as shown:
 Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.06s.
ERROR (OSSSIM): None of the following licenses needed for auLvs could be checked out: Virtuoso_Layout_Suite_XL, Virtuoso_Layout_Suite_GXL( 4 tokens ).
ERROR (OSSSIM): Unable to check out license for OSS capability. Details follow:
ERROR (LMF-02018): License call failed for feature Virtuoso_Layout_Suite_XL, version 6.100 and quantity 1. The license server search path is defined as 1703@mentorgraphics.lic.mst.edu:5280@cadence.lic.mst.edu:. The FLEXnet error message is as follows,
    FLEXnet ERROR(-18, 0, 0): License server system does not support this feature.
Run 'lic_error LMF-02018' for more information.
*WARNING* LIB basic from File /usr/local/cadence_home/sdk8v5/cds.lib Line 2 redefines
LIB basic from File /usr/local/cadence/IC610/tools.lnx86/dfII/etc/cdsDotLibs/composer/cds.lib
Insert UNDEFINE basic
before DEFINE basic
    in /usr/local/cadence_home/sdk8v5/cds.lib
Or remove or comment out DEFINE basic
    in /usr/local/cadence/IC610/tools.lnx86/dfII/etc/cdsDotLibs/composer/cds.lib
to suppress this warning message.
Your key validation has failed.
The Cadence capability 'se' will not run until this problem is resolved.
 Please let me know what the problem might be.
Sambhav
  • Quek
    Quek over 15 years ago
    Hi Sambhav
    Do you have only Virtuoso_Layout_Suite_GXL tokens in your license file? You can check this by using "lmstat -a -c 5280@cadence.clic.mst.edu" cmd in a terminal window. This looks like a bug which has already been reported. The reported bug has the following characteristics:
    a. Happens if only GXL tokens are present
    b. First diva lvs would be ok
    c. Error comes up in 2nd run
    d. Have to restart Virtuoso and rerun lvs in a new directory
    Does the above description fit your situation? Would you also provide the following information?
    terminal>virtuoso -W
    Quek
    Hi Sambhav,
    This is a bug which is described in Cadence Online Support (http://support.cadence.com ) solution 11422616. It was fixed in IC5141 in version 5.10.41.500.5.108 and in IC612 in 6.1.2.500.6 (and later). Not sure what subversion you're using (do Help->About... in the CIW), but you'll need to move to a later subversion to fix this (this fix happened about 2.5 years ago).
    Best Regards,
  • Sambhav
    @Qwek,
    I ran the command lmstat -a -c 5280@cadence.clic.mst.edu
    and here's the output:
    -bash-3.2$ lmstat -a -c 5280@cadence.lic.mst.edu
    lmstat - Copyright (c) 1989-2007 Macrovision Europe Ltd. and/or Macrovision Corp
    oration. All Rights Reserved.
    Flexible License Manager status on Fri 9/24/2010 13:05
    License server status: 5280@license5.srv.mst.edu
        License file(s) on license5.srv.mst.edu: E:\Flexlm\Vendor Daemons\Cadence\cd
    slmd.lic:
    license5.srv.mst.edu: license server UP (MASTER) v11.4
    Vendor daemon status (on license5.srv.mst.edu):
        cdslmd: UP v10.8
    Feature usage info:
    Users of 111:  (Total of 3900 licenses issued;  Total of 0 licenses in use)
    Users of 12141:  (Total of 300 licenses issued;  Total of 0 licenses in use)
    Users of 21060:  (Total of 300 licenses issued;  Total of 0 licenses in use)
    Users of 21400:  (Total of 300 licenses issued;  Total of 0 licenses in use)
    Users of 276:  (Total of 300 licenses issued;  Total of 0 licenses in use)
    Users of 32150:  (Total of 300 licenses issued;  Total of 0 licenses in use)
    Users of 32760:  (Total of 300 licenses issued;  Total of 0 licenses in use)
    Users of 365:  (Total of 1200 licenses issued;  Total of 0 licenses in use)
    Users of 940:  (Total of 600 licenses issued;  Total of 0 licenses in use)
    Users of 945:  (Total of 600 licenses issued;  Total of 0 licenses in use)
    Users of AMS_Designer_Link:  (Total of 300 licenses issued;  Total of 0 licenses
     in use)
    Users of AMS_environment:  (Total of 300 licenses issued;  Total of 0 licenses i
    n use)
    Users of Affirma_sim_analysis_env:  (Total of 3000 licenses issued;  Total of 0
    licenses in use)
    Users of Allegro_PCB_Router_610:  (Total of 1500 licenses issued;  Total of 0 li
    censes in use)
    Users of Allegro_Package_Designer_620:  (Total of 300 licenses issued;  Total of
     0 licenses in use)
    Users of Allegro_Package_Designer_XL_II:  (Total of 300 licenses issued;  Total
    Users of Allegro_design_expert:  (Total of 600 licenses issued;  Total of 0 lice
    nses in use)
    Users of Allegro_studio:  (Total of 300 licenses issued;  Total of 0 licenses in
     use)
    Users of Analog_Design_Environment_GXL:  (Total of 3600 licenses issued;  Total
    Users of Analog_Design_Environment_XL:  (Total of 300 licenses issued;  Total of
     0 licenses in use)
    Users of Assura_DRC:  (Total of 300 licenses issued;  Total of 0 licenses in use
    Users of Assura_DV_LVS_checker:  (Total of 300 licenses issued;  Total of 0 lice
    nses in use)
    Users of Assura_DV_design_rule_checker:  (Total of 300 licenses issued;  Total o
    Users of Assura_DV_parasitic_extractor:  (Total of 300 licenses issued;  Total o
    Users of Assura_LVS:  (Total of 300 licenses issued;  Total of 0 licenses in use
    Users of Assura_MP:  (Total of 300 licenses issued;  Total of 0 licenses in use)
    Users of Assura_UI:  (Total of 900 licenses issued;  Total of 0 licenses in use)
    Users of Base_Verilog_Lib:  (Total of 300 licenses issued;  Total of 0 licenses
    in use)
    Users of Cadence_chip_assembly_router:  (Total of 300 licenses issued;  Total of
     0 licenses in use)
    Users of Conformal_Asic:  (Total of 300 licenses issued;  Total of 0 licenses in
     use)
    Users of Conformal_Custom:  (Total of 300 licenses issued;  Total of 0 licenses
    in use)
    Users of Conformal_Ultra:  (Total of 300 licenses issued;  Total of 0 licenses i
    n use)
    Users of DFM_Core_Technology:  (Total of 1500 licenses issued;  Total of 0 licen
    ses in use)
    Users of DRAC2CORE:  (Total of 900 licenses issued;  Total of 0 licenses in use)
    Users of DRAC3CORE:  (Total of 900 licenses issued;  Total of 0 licenses in use)
    Users of DRAC3DRC:  (Total of 300 licenses issued;  Total of 0 licenses in use)
    Users of DRAC3LVS:  (Total of 300 licenses issued;  Total of 0 licenses in use)
    Users of DRACDIST:  (Total of 900 licenses issued;  Total of 0 licenses in use)
    Users of DRACERC:  (Total of 600 licenses issued;  Total of 0 licenses in use)
    Users of DRACLPE:  (Total of 300 licenses issued;  Total of 0 licenses in use)
    Users of DRACLVS:  (Total of 300 licenses issued;  Total of 0 licenses in use)
    Users of DRACPRE:  (Total of 300 licenses issued;  Total of 0 licenses in use)
    Users of Distributed_Dracula_Option:  (Total of 900 licenses issued;  Total of 0
     licenses in use)
    Users of Encounter_C:  (Total of 300 licenses issued;  Total of 0 licenses in us
    e)
    Users of Encounter_Library_Char_XL:  (Total of 300 licenses issued;  Total of 0
    licenses in use)
    Users of Encounter_Power_System_L:  (Total of 300 licenses issued;  Total of 0 l
    icenses in use)
    Users of Encounter_Test_Architect:  (Total of 300 licenses issued;  Total of 0 l
    icenses in use)
    Users of Encounter_Timing_System_L:  (Total of 300 licenses issued;  Total of 0
    licenses in use)
    Users of Encounter_Timing_System_XL:  (Total of 300 licenses issued;  Total of 0
     licenses in use)
    Users of Encounter_True_Time:  (Total of 300 licenses issued;  Total of 0 licens
    es in use)
    Users of Encounter_Wave_Viewer:  (Total of 300 licenses issued;  Total of 0 lice
    nses in use)
    Users of Extended_Verilog_Lib:  (Total of 300 licenses issued;  Total of 0 licen
    ses in use)
    Users of Fire_Parallel:  (Total of 7500 licenses issued;  Total of 0 licenses in
     use)
    Users of Ice_Parallel:  (Total of 7500 licenses issued;  Total of 0 licenses in
    use)
    Users of Incisive_Desktop_Manager:  (Total of 600 licenses issued;  Total of 0 l
    icenses in use)
    Users of Incisive_Enterprise_ESL_Option:  (Total of 300 licenses issued;  Total
    Users of Incisive_Enterprise_ESL_inter:  (Total of 300 licenses issued;  Total o
    Users of Incisive_Enterprise_Manager:  (Total of 300 licenses issued;  Total of
    0 licenses in use)
    Users of Incisive_Enterprise_Planner:  (Total of 300 licenses issued;  Total of
    0 licenses in use)
    Users of Incisive_Enterprise_Simulator:  (Total of 300 licenses issued;  Total o
    Users of Incisive_Formal_Verifier:  (Total of 300 licenses issued;  Total of 0 l
    icenses in use)
    Users of Incisive_HDL_Simulator:  (Total of 300 licenses issued;  Total of 0 lic
    enses in use)
    Users of Incisive_P2C_Methodology:  (Total of 600 licenses issued;  Total of 0 l
    icenses in use)
    Users of Incisive_Specman_interactive:  (Total of 300 licenses issued;  Total of
     0 licenses in use)
    Users of Incisive_Verif_Environ:  (Total of 300 licenses issued;  Total of 0 lic
    enses in use)
    Users of LEAPFROG-CV:  (Total of 900 licenses issued;  Total of 0 licenses in us
    e)
    Users of MTI_Opt_Incisive_Specman_Sim:  (Total of 300 licenses issued;  Total of
     0 licenses in use)
    Users of OASIS_RFDE:  (Total of 300 licenses issued;  Total of 0 licenses in use
    Users of OASIS_Simulation_Interface:  (Total of 300 licenses issued;  Total of 0
     licenses in use)
    Users of PAS_Assura_Drc_Generator:  (Total of 300 licenses issued;  Total of 0 l
    icenses in use)
    Users of PAS_Assura_Lvs_Generator:  (Total of 300 licenses issued;  Total of 0 l
    icenses in use)
    Users of PAS_Diva_Drc_Generator:  (Total of 300 licenses issued;  Total of 0 lic
    enses in use)
    Users of PAS_Diva_Lvs_Generator:  (Total of 300 licenses issued;  Total of 0 lic
    enses in use)
    Users of PAS_Dracula_Drc_Generator:  (Total of 300 licenses issued;  Total of 0
    licenses in use)
    Users of PAS_Dracula_Lvs_Generator:  (Total of 300 licenses issued;  Total of 0
    licenses in use)
    Users of PAS_ErrorCell_Generator:  (Total of 300 licenses issued;  Total of 0 li
    censes in use)
    Users of PAS_Graphical_Tech_Editor:  (Total of 300 licenses issued;  Total of 0
    licenses in use)
    Users of PAS_Pcell_Generator:  (Total of 300 licenses issued;  Total of 0 licens
    es in use)
    Users of PCB_design_expert:  (Total of 600 licenses issued;  Total of 0 licenses
     in use)
    Users of PCB_librarian_expert:  (Total of 300 licenses issued;  Total of 0 licen
    ses in use)
    Users of PSpiceStudio:  (Total of 300 licenses issued;  Total of 0 licenses in u
    se)
    Users of Pacific_Noise_Analyzer:  (Total of 300 licenses issued;  Total of 0 lic
    enses in use)
    Users of PlaceBase_ALL:  (Total of 600 licenses issued;  Total of 0 licenses in
    use)
    Users of RTL_Compiler_Ultra:  (Total of 300 licenses issued;  Total of 0 license
    s in use)
    Users of RTL_Compiler_Ultra_II_Option:  (Total of 300 licenses issued;  Total of
     0 licenses in use)
    Users of RouteMVIA_ALL:  (Total of 900 licenses issued;  Total of 0 licenses in
    use)
    Users of SIP_Digital_Architect_GXL_II:  (Total of 300 licenses issued;  Total of
     0 licenses in use)
    Users of SIP_Digital_Layout_GXL_II:  (Total of 300 licenses issued;  Total of 0
    licenses in use)
    Users of SIP_Digital_SI_XL_II:  (Total of 300 licenses issued;  Total of 0 licen
    ses in use)
    Users of SIP_RF_Layout_GXL_II:  (Total of 300 licenses issued;  Total of 0 licen
    ses in use)
    Users of SOC_Encounter_GPS:  (Total of 300 licenses issued;  Total of 0 licenses
     in use)
    Users of SPECCTRAQuest:  (Total of 300 licenses issued;  Total of 0 licenses in
    use)
    Users of SPECCTRAQuest_SI_expert:  (Total of 300 licenses issued;  Total of 0 li
    censes in use)
    Users of SPECCTRAQuest_signal_expert:  (Total of 300 licenses issued;  Total of
    0 licenses in use)
    Users of SPECCTRA_expert:  (Total of 900 licenses issued;  Total of 0 licenses i
    n use)
    Users of SiP_RF_Architect_XL:  (Total of 300 licenses issued;  Total of 0 licens
    es in use)
    Users of Spectre_Burst_AllegroSI:  (Total of 900 licenses issued;  Total of 0 li
    censes in use)
    Users of Test_Design_Analysis:  (Total of 600 licenses issued;  Total of 0 licen
    ses in use)
    Users of Test_Extension_Language:  (Total of 900 licenses issued;  Total of 0 li
    censes in use)
    Users of Test_Mfg_Fault_Isolation:  (Total of 1200 licenses issued;  Total of 0
    licenses in use)
    Users of ULTRASIM:  (Total of 300 licenses issued;  Total of 0 licenses in use)
    Users of VCS_Opt_Incisive_Specman_Sim:  (Total of 300 licenses issued;  Total of
     0 licenses in use)
    Users of VERILOG-XL:  (Total of 600 licenses issued;  Total of 0 licenses in use
    Users of Virtuoso_Layout_Suite_GXL:  (Total of 3600 licenses issued;  Total of 0
     licenses in use)
    Users of Virtuoso_Multi_mode_Simulation:  (Total of 1800 licenses issued;  Total
    Users of Virtuoso_QRC_Extraction_GXL:  (Total of 300 licenses issued;  Total of
    0 licenses in use)
    Users of Virtuoso_QRC_Extraction_L:  (Total of 300 licenses issued;  Total of 0
    licenses in use)
    Users of Virtuoso_QRC_Extraction_XL:  (Total of 300 licenses issued;  Total of 0
     licenses in use)
    Users of Virtuoso_Schematic_Editor_XL:  (Total of 300 licenses issued;  Total of
     0 licenses in use)
    Users of Virtuoso_Spectre:  (Total of 300 licenses issued;  Total of 0 licenses
    in use)
    Users of Virtuoso_Spectre_GXL_MMSIM_Lk:  (Total of 1800 licenses issued;  Total
    Users of Virtuoso_Spectre_RF:  (Total of 300 licenses issued;  Total of 0 licens
    es in use)
    Users of VoltageStorm_Transistor:  (Total of 300 licenses issued;  Total of 0 li
    censes in use)
    Users of evc_cadence_ahb:  (Total of 300 licenses issued;  Total of 0 licenses i
    n use)
    Users of evc_cadence_axi:  (Total of 300 licenses issued;  Total of 0 licenses i
    n use)
    Users of evc_cadence_pcie:  (Total of 600 licenses issued;  Total of 0 licenses
    in use)
    Users of evc_cadence_pcie_ep:  (Total of 300 licenses issued;  Total of 0 licens
    es in use)
    Users of evc_cadence_pcie_rc:  (Total of 300 licenses issued;  Total of 0 licens
    es in use)
    Users of evc_cadence_usb:  (Total of 300 licenses issued;  Total of 0 licenses i
    n use)
    Users of evc_cadence_usb_otg:  (Total of 300 licenses issued;  Total of 0 licens
    es in use)
    Users of expgen:  (Total of 600 licenses issued;  Total of 0 licenses in use)
    Users of pcomp:  (Total of 600 licenses issued;  Total of 0 licenses in use)
    Users of plotVersa:  (Total of 2700 licenses issued;  Total of 0 licenses in use
    Users of skillDev:  (Total of 300 licenses issued;  Total of 0 licenses in use)
    Users of verifault:  (Total of 300 licenses issued;  Total of 0 licenses in use)
    Users of evc_verisity_enet: Cannot get users of evc_verisity_enet: No such featu
    re exists. (-5,222)
    Users of evc_verisity_pci: Cannot get users of evc_verisity_pci: No such feature
     exists. (-5,222)
    Users of conformal_datapath: Cannot get users of conformal_datapath: No such fea
    ture exists. (-5,222)
    Users of conformal_ldd: Cannot get users of conformal_ldd: No such feature exist
    s. (-5,222)
    Users of conformal_lec: Cannot get users of conformal_lec: No such feature exist
    s. (-5,222)
    Users of conformal_lvr: Cannot get users of conformal_lvr: No such feature exist
    s. (-5,222)
    Users of conformal_mem: Cannot get users of conformal_mem: No such feature exist
    s. (-5,222)
    Users of conformal_vhd: Cannot get users of conformal_vhd: No such feature exist
    s. (-5,222)
    Users of conformal_vlg: Cannot get users of conformal_vlg: No such feature exist
    s. (-5,222)
    Users of transformal_ltx: Cannot get users of transformal_ltx: No such feature e
    xists. (-5,222)
     verisityd: No such feature exists. (-5,222)
       verplex: No socket connection to license server manager. (-7,96)
    It looks like what you said is correct. When i run LVS for the first time, it works fine. But on subsequent runs it throws up the error. Also, if i restart and run lvs in a new directory, it works for the first time.
    Is there a permanent solution to this using Layout L?
    When i use Layout GXL, LVS works fine.. but doesn't work with Layout L.
    Sambhav
  • Quek
    Hi Sambhav
    I think using layoutGXL might be the only workaround. It would be great if you can also report this to Cadence support so that it can be quickly fixed. Please highlight that you are experiencing the problem in CCR776148.
    When reporting a problem, please include the following information:
    Quek
