  3. cadence IC problem
  • Views 16631
cadence IC problem
BIGP
BIGP over 15 years ago
Hello!   I installed IC 5141_usr6(32bit) on the server (CENTOS 5.4(64bit))
when I logined in the software, the CIW windows had many Error messages like following texts
*Error* loadContext: could not open file - "/usr/cad/cadence/IC/cur/tools/SKILL06.30/context/skillCore.cxt"
*WARNING* (autoloads): skillCore.cxt was not loaded
Loading Skill files for skillCore
*Error* load: can't access file - "startup.il"
*WARNING* (context init): failed to load context
*Error* eval: undefined function - defmacro
*Error* eval: undefined function - not
*Error* eval: undefined function - mpsExport
*Error* eval: undefined function - push
*Error* eval: undefined function - defPrereq
*WARNING* (loadContext): could not restore method, undefined generic printObject standardObject
*Error* arrayref: can't handle nil["sim-env:simulator-started"]
*Error* arrayref: can't handle nil["sim-env:start-sim-session"]
*Error* arrayref: can't handle nil["sim-env:simulation-complete"]
*Error* arrayref: can't handle nil["sim-env:simulation-requested"]
etc...the same Error messages  repeat again and again
END OF SITE CUSTOMIZATION
How should I modify this problem?
    First thing to check is if that file (/usr/cad/cadence/IC/cur/tools/SKILL06.30/context/skillCore.cxt) is actually present and that you as the user have permissions to read it.
    I can't think of any other reasons why this problem should occur. Check the permissions on the containing directory too.
  • BIGP
    Hi, Dear Andrew
    I had been modified that problem, like you said ,I didn't see any file in my documents.
    But another problem is that when I want to create a new library , CIW windows will display a message
    "ApplicationManager.setFileOutputStream(): cannot create output stream."
    Do you have any idea about this problem? Thank you !
    I found a couple of references to that message. It wasn't clear in either case where it came from (it didn't seem to be anything to do with creating a library) - certainly wasn't reproducable at Cadence.
    Does it actually stop the library being created? If so, is the directory where you're trying to create the library writable?
