  3. Meta key binding not working in Cadence 6.1.4
  • Views 15721
JaiM
JaiM over 15 years ago
I have defined a key mapping in Unix for the metal key by running:
 xmodmap -e "keycode 115 = Meta_L"
But, when I launch Cadence it still complains that:
*WARNING* Modifier Meta is unassigned, illegal or disabled.
*WARNING* Invalid bindkey key string: Meta<Key>a
I have tried binding the key to "Super" as well without any luck. Any ideas on how I can get this to work?
  • dmay
    dmay over 15 years ago
    What do you get when you run this command?
     _hiGetModifierList()
    I saw this problem in the pre-release of 6.1.4, but the bug was fixed.
    Derek
  • skillUser
    skillUser over 15 years ago
    Hi Jai,
    There is a solution that appears to answer your question, Solution 11495912, also it mentions the hiBindKeyModifiers() function - look to see if Meta is in the list returned.  Another solution that might be relevant is Solution 11209364, take a look there too.
    Hope this helps,
    Lawrence.
