  3. about assura error
  • Views 14921
about assura error
CCH01
CCH01 over 15 years ago
Hi~all
I met a problem about Assura recently.
I installed Assura 3.17 with IC 5141_USR6 on CENTOS 5.3 x86_64.
When I want to execute DRC with Assura, it will show the DRC failed
the logfile said that "/usr/cad/cadence/ASSURA/cur/tools/assura/bin/32bit/assura: error while loading shared libraries: libm.so.6: cannot open shared object file: No such file or directory"
I had searched some information on the internet, but I can't get the correct method to solve this problem.
Someone advised me try to use another version of centos like centos 4.6.
But I don't really want to reinstall the OS again!
Does anyone have some better detailed solution ?
Best regard
  • Quek
    Quek over 15 years ago
    Hi CCH01
    Only Assura3.2 and above will work on rhel5. So your easier alternative is to download and install the latest version of Assura (Assura410-018). : )
    Best regards
    Quek
  • CCH01
    Hi ~ Quek
    Thank you for your help~ I have updated new version of assura, it can work normally now.
    Best regards
