  3. Problem with Simulation
  • Views 15711
tianyvonne
tianyvonne over 15 years ago
I have tried several times but the result is the same with following problems. If anyone has answers, please reply me. Thanks.
Loading /mnt/pollux/software/cadence/MMSIM70/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
Loading /mnt/pollux/software/cadence/MMSIM70/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
Loading /mnt/pollux/software/cadence/MMSIM70/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
Loading /mnt/pollux/software/cadence/MMSIM70/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
Using new Spectre Parser.
Error found by spectre in `_sub0', during circuit read-in.
    ERROR (SFE-23): "input.scs" 14: M2 is an instance of an undefined model PMOS_VTG.
    ERROR (SFE-23): "input.scs" 15: M1 is an instance of an undefined model PMOS_VTG.
    ERROR (SFE-23): "input.scs" 16: M0 is an instance of an undefined model PMOS_VTG.
    ERROR (SFE-23): "input.scs" 17: M8 is an instance of an undefined model NMOS_VTG.
    ERROR (SFE-23): "input.scs" 18: M7 is an instance of an undefined model NMOS_VTG.
    ERROR (SFE-23): "input.scs" 19: M5 is an instance of an undefined model NMOS_VTG.
    ERROR (SFE-23): "input.scs" 20: M9 is an instance of an undefined model NMOS_VTG.
    ERROR (SFE-23): "input.scs" 21: M3 is an instance of an undefined model NMOS_VTG.
    ERROR (SFE-23): "input.scs" 22: CCOMP is an instance of an undefined model ccomp.
spectre terminated prematurely due to fatal error.
  • NCTUEEDSTUDENT
    NCTUEEDSTUDENT over 11 years ago
    I know it has been 5 years since you asked the question.
    Maybe you already fixed this problem.
    However, because I met this problem in the earlier time.
    So I share the way I fixed it with you.
    You see. It's basically the same error.
    Loading /usr/mmsim61/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
    Loading /usr/mmsim61/tools.lnx86/cmi/lib/5.0/libnortel_sh.so ...
    Loading /usr/mmsim61/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
    Loading /usr/mmsim61/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
    Loading /usr/mmsim61/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
    spectre (ver. 6.1.1.133 -- 20 Nov 2006).
    Protected by U.S. Patents: 5,610,847; 5,790,436; 5,812,431; 5,859,785; 5,949,992; 5,987,238; 6,088,523; 6,101,323; 6,151,698; 6,181,754; 6,260,176; 6,278,964; 6,349,272; 6,374,390; 6,493,849; 6,504,885; 6,618,837; 6,636,839; 6,778,025; 6,832,358; 6,851,097; 7,035,782; 7,085,700
    Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
    Simulating `input.scs' on ee03 at 6:15:28 PM, Mon Apr 20, 2015.
    "input.scs" 13: M11 is an instance of an undefined model n_33_mm.
    "input.scs" 15: M10 is an instance of an undefined model n_33_mm.
    "input.scs" 17: M9 is an instance of an undefined model n_33_mm.
    "input.scs" 21: C0 is an instance of an undefined model mimcaps_mm.
    "input.scs" 22: R3 is an instance of an undefined model rnnpo_mm.
    "input.scs" 23: R2 is an instance of an undefined model rnnpo_mm.
    "input.scs" 24: R1 is an instance of an undefined model rnnpo_mm.
    "input.scs" 25: R0 is an instance of an undefined model rnnpo_mm.
    "input.scs" 26: M7 is an instance of an undefined model p_33_mm.
    "input.scs" 29: M6 is an instance of an undefined model p_33_mm.
    "input.scs" 32: M5 is an instance of an undefined model p_33_mm.
    "input.scs" 35: M4 is an instance of an undefined model p_33_mm.
    "input.scs" 38: M3 is an instance of an undefined model p_33_mm.
    "input.scs" 41: M1 is an instance of an undefined model p_33_mm.
    "input.scs" 43: M2 is an instance of an undefined model p_33_mm.
    Here is the way I fixed it.
    You go to the "Analog Design Environment" window and click "Setup".
    Then "Model libraries".
    If the largest row is empty, follow the steps below.
    1.Click "Property".
    2.Click every element, source, symbol one by one in you schematic, then click "Ok" in the "Edit Object Properties" window.
    3.Go to the "Model libraries" again. It's not empty anymore!
    4.Continue your simulation.
    But I am not sure this way is temporary or permanent.
    Hope it's helpful!
    Best Regards.
    Shih-Hsing Chen(陳世興).
