  3. default simulation states when using ADE-L
  • Views 16890
vivkr
vivkr over 15 years ago
Each time I start an ADE-L session, I get a set of default simulation settings automatically loaded. These are taken from one simulation setup which I had once made, and are automatically used as default for some reason, even though I never specified those as my default conditions.
For instance, I get a "tran" analysis which I always have to modify. Why does ADE-L "know" that this is a default state it ought to load each time? How can I get rid of this?
Vivek
    Hi Vivek,
    You probably did an Options->Save Defaults with an ADE window open, and created a .cdsenv file in your home directory. Try moving that aside, and restart virtuoso/icfb - that should fix it.
  • vivkr
     OK! I do see all those ghosts of the past tucked away in that .cdsenv. I will have to edit out those, as I do use the .cdsenv to save some settings, mainly for layout.
    Vivek
