  3. APS: AC during TRAN option ignored
  • Views 14926
vivkr
vivkr over 15 years ago
 I wanted to run AC analysis at various time instants during my TRAN analysis. So I setup an AC analysis, and in the TRAN options,I selected "actimes = t1 t2 t3 ...", and "acnames = ac". However, the simulation log shows me that no AC analysis was done at any of the specified timepoints, but only once as a separate analysis. Do I need to specify something else in addition?
Vivek
    Hi Vivek,
    My guess is that you're using MMSIM72? Not all analyses were supported in APS mode in MMSIM72. If I use MMSIM72, I see the problem you're seeing, but it works correctly in MMSIM101.
    So please try MMSIM101 instead.
    Best Regards,
  • vivkr
    Andrew,
    We haven't got an MMSIM101 installation here. I checked the list of available versions and the latest one is MMSIM 7.20.349, which would be the MMSIM72 you are talking about. So, I suppose that I need to run the simulation without using the APS option for now, although that would be much much slower.
    Vivek
