  3. Setup for a contact
  • Views 16033
Setup for a contact
J Wilwert
J Wilwert over 15 years ago
I would like to be able to set parameters for the leHiCreateContact() command. Can I use skill to write/modify a file for this?
I am using Cadence Virtuoso 5.41.
John Wilwert
    Hi John,
    Your question is a bit vague, so I'll guess at two possible answers. If you're wanting a procedural way of creating a contact in IC5141, you can use leCreateContact (rather than the "Human Interface" version of the function). If you're wanting to alter the contacts that are placed, that's a matter of defining them in the tech file, and maybe writing a pcell.
    If neither of these answers the question  you meant to ask, please give sufficient details so that we can understand what your objective is.
  • J Wilwert
    Thanks for your response.  My apologies for being a bit vague.
    I would like to use the leHiCreateContact() command as it will let me use the mouse to actually place the contacts as I need them.  When this form pops up, it uses default values it obtains from some place.  When this form pops  up, I would like to see the default values be the values I used the last time I used this form.  Any insights?
     Again, THANKS!
    John Wilwert
    John,
    The initial defaults come from the tech file. However, you can avoid it resetting each time by using:
    envSetVal("layout" "contactResetRowCol" 'boolean nil)
    envSetVal("layout" "contactResetDelXY" 'boolean nil)
    envSetVal("layout" "contactResetXYBias" 'boolean nil)
    There are also other cdsenv values if it's a cdsVia :
    layout cdsViaResetXYCutSpacing boolean t
    layout cdsViaResetLayer1XYEnclosure boolean t
    layout cdsViaResetLayer2XYEnclosure boolean t
    layout cdsViaResetLayer1XYDirEnclosure boolean t
    layout cdsViaResetLayer2XYDirEnclosure boolean t nil
    layout cdsViaResetLayerDirection boolean t
    layout cdsViaResetOrigin boolean t
  • J Wilwert
    Andrew,
    Thanks - This is exactly what I needed!
    John Wilwert
