  3. Elaboration error in AMS simulator
  • Views 18104
kasyab
kasyab over 15 years ago
   I am a newbie with AMS and am using IC-5.1.41.USR5 to run a mixed signal simulation with Verilog AMS, vhdl and schematic components. I run the simulation from the configuration  -> schematic (open) -> Analog Environment. Under setup I choose the ams simulator and setup the correct model files. I checked the netlisting options and saw that the cell based netlister is being used. However, netlisting goes through without any errors. Elaboration  produces the following error:
 *F,DLPAKO (No HDL source,0|0): Unable to open packed library for functional (Permission denied).
A packed library was found in initialization. However,
ncelab failed to open it. This may be caused by permissions
problems or by interference from another process or user.
 This is the complete error shown by NC-Browse. I am unable to figure out which library is being referred to here. Any tips in tracing this back would help.
 Thanks.
Kasyab
    Kasyab,
    Which IUS/INCISIV version are you using (should show up in the log files, but ncsim -version would tell you too)?
  • kasyab
     ncsim -version reports ncsim 08.20-s012.
    Kasyab
  • kasyab
     As it turns out the solution to this problem is in the file permissions. The elaborator was looking for read permissions on the 'functional' library in the installation path of Virtuoso. The group permissions once adjusted to r-x ensured that the simulation ran to completion.
     There was no fault with the set up or with the way in which the simulation was being run.
    Kasyab
