  3. Unreadable font in cdshelp
  • Replies 11
  • Views 22108
SharksFan
SharksFan over 15 years ago
This seems like such a lame issue to post here, but I've searched around and cannot find a solution yet.
My problem is that the font used in the cdshelp browser is unreadable for me.  It's small, cramped, and grainy.
I'm running Cadence on Java Desktop System for Solaris, which has a Gnome display interface. I'm launching Cadence Help v01.20-p009 from the IC6.1.4.500.7 release.
I'm attaching an image for people to look at so you can understand.
    Andrew Beckett over 6 years ago in reply to LukeAndrew +1
    Hi Luke, Thanks for the clear description - this really should have been a separate and new thread because it's not really anything to do with the earlier (very old) issue, but anyway, it's done now…
    Andrew Beckett over 6 years ago in reply to Andrew Beckett +1
    Hi Luke, It turns out that this is indeed fixed in the latest cdnshelp versions. You can download the "CADENCEHELP" release (from March 2020) on http://downloads.cadence.com which is a standalone release…
    I'm looking into a similar issue for another customer (in fact I had a problem myself too, although not as severe), under CCR 857785.
    I'll report back here once I've found out some more things to try (I'm working with R&D and another colleague to see if we can get to the bottom of it).
    In my case I had a font package installed on my Linux machine to give me Microsoft True Type fonts - uninstalling that package fixed my problem. Anyway, we're trying to get to the bottom of exactly how it picks the fonts, more later once I've got more info.
  • SharksFan
    Thanks Andrew,
    It wasn't always this way for me, but the IT group at my company saw fit to overwrite my profile with all of their own settings recently, as a way to resolve a different problem I was having.  Bad idea. :(  It's been a nightmare getting everything back to a usable state again and I still have the other problem! [Sorry for the venting]  I've tried looking through all the .gnome and .gtkrc dirs and files, but no luck.
    I am assuming this problem is related, due to the timing of it cropping up only after my settings were changed. Of course, it could just be a coincidence.
    I appreciate your quick reply. It's good to know I'm not alone.
  • GiuseppeDG
    GiuseppeDG over 13 years ago
    Finally, did you find a solution for this issue? I have to too small fonts in cdnshelp.
     If you're using a current version (cdnshelp from MMSIM12.1) and you are still seeing this problem, please contact customer support.
    Kind Regards,
  • LukeAndrew
    LukeAndrew over 6 years ago in reply to Andrew Beckett
    Hello. I also have a problem with too small GUI font size in  cdnshelp. The thread is quite old, so I would like to ask if any standard solution to this problem has already been developed?
    Luke
    Hi Luke,
    It would be useful to know which version you're using. There's a Help->About menu in cdnshelp which should give the precise version number. How are you invoking cdnshelp? Is it from a help menu in Virtuoso? (If so, Help->About in Virtuoso would help too). Or from the command line, in which case "which cdnshelp" would be good to know - which release stream.
    I suspect this is a long-fixed problem and you're using some old version, but let's see based on the information you provide.
    Oh, and a screenshot of the problem would help.
  • LukeAndrew
    Actually, the problem is not that there is some terrible font quality. It is regular 10 or 11 pt font, I guess, which is fine for older displays. However, I am using 4K UHD display and on such a display this size is too small.
    For all other Virtuoso windows I simply use the following code in .cdsinit_local:
    hiSetFont("label" ?size 14)
    hiSetFont("ciw" ?size 14)
    hiSetFont("text" ?size14)
    and it works fine. However, these settings do not affect Cadence Help GUI font size. I would like to be able to adjust it to meet my preferences.
    I use Virtuoso version IC6.1.7-64b.500.7, and I invoke cdnshelp (version is 02.30-p005) from the Virtuoso menu.
    Attached below is the image with fonts that I am not able to enlarge shown in red rectangles and fonts that I was able to enlarge (either using system settings or cdnshelp preferences) shown in green rectangles.
    Hi Luke,
    Thanks for the clear description - this really should have been a separate and new thread because it's not really anything to do with the earlier (very old) issue, but anyway, it's done now.
    Unfortunately I've found no way of solving this, either in the version you're using or later versions. There have been a few change requests which suggest that this should be "fixed" but I can't see any sign of how it was actually fixed, so I'm asking R&D. If I find anything, I'll let you know.
    Hi Luke,
    It turns out that this is indeed fixed in the latest cdnshelp versions. You can download the "CADENCEHELP" release (from March 2020) on http://downloads.cadence.com which is a standalone release containing the help tool - you'd have to launch it directly yourself and search within the tool (you can add libraries of documentation from the settings menu though). In this, the font size in the setting is reflected in the navigator (I tried it).
    It's due to be the version of help in the next SPECTRE191 hot fix, and I assume in an upcoming IC618 build too (I don't know for certain).
  • MRankind1990
    MRankind1990 over 6 years ago in reply to Andrew Beckett
    "CADENCEHELP" release helped me. Thanks for your reply
    Best regards,
