  3. Issue with Wavescan:
  • Views 17031
boulot
boulot over 15 years ago
 Sometime it appends that Wavescan doesn't plot all the simulation results: If I run a simulation of 3 seconds it cut the plot a 10ms without  error message. It seems to be random.
 Thanks for your help!
  • Quek
    Quek over 15 years ago
    Hi boulot
    Would you please try the latest version of Virtuoso and see if it still happens? May I know the current version which you are using?
    linux>icfb -W
    Best regards
    Quek
  • boulot
     Hi Quek,
     Thanks for your reply.
    THis is not the lastest version of Cadence. I use 5.10 version.
  • Quek
    Hi boulot
    Actually I have also seen this problem come and goes in the different subversions of IC5141. By the way, it is important to provide the full version info (e.g. IC5.1.41.500.6.146) because IC5.1.x is at least 5 years old and so it is hard to guess the specific version which you are using. I have recently encountered the same problem and it seems that it does not occur for the latest version IC5141.500.6.146. Please consider changing to this version and retry. : )
    Best regards
    Quek
  • boulot
     OUps, effectively this the  5.10.41.500.4.83 ! So no way about my problem ! Thanks;)
    Can you do an "ls -al" in your psf directory? If the results files are bigger than 2Gbytes, it may be because you're running spectre from an MMSIM release, where the default is to use single large files, whereas IC5141 still requires you to use the old "chunking" method.
    This is enabled using "setenv PSF_WRITE_CHUNK_MODE_ON true" before starting icfb. This is described in more detail in Solution 11264780 .
    BTW, the sub-version of IC5141 you're using is probably at least 4 years old (icfb -V will tell you the date). There have been two main updates and a lot of hotfixes since then.
  • boulot
     Thanks for your support.
