  3. Spaced-based router
  • Views 16357
Spaced-based router
brianzimmer
brianzimmer over 15 years ago
Automatic routing is producing many DRC errors by not aligning wires with pins and/or vias. I've tried every routing setting/technology file constraint to prevent this but am at a loss. Any ideas? Thanks, Brian
  • Quek
    Quek over 15 years ago
    Hi Brian
    Adding drc constraints in the Virtuoso techfile is the correct approach so the problem should be resolved if the right constraints have been added. You can also try using the latest version of VSR (IC615.72) and see if the same problem occurs. May I know the version of VSR which you are using.
    terminal>virtuoso -W
    Best regards
    Quek
  • brianzimmer
    My version is: sub-version IC6.1.4.500.9 I tried adding various constraints myself pertaining to edge width, but nothing seemed to prevent this. Do you have any idea what rule would prevent something like this?
  • Quek
    Hi Brian
    Would you please post the specific DRC message for the shapes which you have uploaded? Previously I had resolved similar errors using minEdgeAdjacentDistance constraint. You can look it up in $CDSHOME/doc/asciitechfile/asciitechfile.pdf.
    Best regards
    Quek
  • brianzimmer
    Here is the message: M1 vertex must not be connected to two short edges with length
  • Quek
    Would you please try to add minEdgeAdjacentLength and see if it resolves the problem? If you already have this constraint in the techfile, then it might be good to see if VSR615 makes a difference.
