  3. How do I control CDLIn generating User Property information...
  • Views 17226
How do I control CDLIn generating User Property information?
Amanda2
Amanda2 over 15 years ago
Hi, I'm generating schematics from a CDL file via CDLIn. The devices are mapping OK except I have an issue with the additional User Property values that are being attached to the instances. Mostly this is a property called 'subtype' but I also have 'perim' for a diode. Example of netlist, .SUBCKT INV Y A VDD VSS M1 Y A VSS VSS NCH_HVT w=0.5u L=0.1U M=1 M0 VDD A Y VDD PCH_HVT w=0.5u L=0.1U M=1 .ends INV Example of dev.map file, devMap := nfet nch_hvt_dnw devMap := pfet pch_hvt devMap := diode ndio_hvt After the schematic has been generated, I check the instance properties, and above the CDF Parameter section there is an additional User Property section with, User Property = subtype Local Value = PC I understand that you can add User Properties and they can be useful, but I don't understand the purpose of it here, and more importantly, I don't know how to stop it being added. With regard to the diode, the area value gets mapped across but the perimeter value doesn't and ends up in the User Property box with the subtype. I have tried using propMap but was unsuccessful. Thank you for any help you can provide. Amanda
  • Quek
    Quek over 15 years ago
    Hi Amanda
    This is most probably because you had not used the correct cdf property names in the mapping file. You can check the cdf form of the diode for the name of the perimeter parameter. Most pdks use "pj" so perhaps you can try this:
    propMap := area area perim pj
    If this does not work, perhaps you can dump out the cdf info and upload it as an attachment. Please also provide the mapping file.
    Best regards
    Quek
  • Amanda2
    Thanks Quek, that fixed the perim problem, it was called "pj". However, I'm still unsure how to stop the "subtype" User Property being added to all my instances. Many thanks, Amanda
  • Quek
    Hi Amanda
    Would you please upload your device mapping file?
    Quek
  • Amanda2
    Hi Quek, Hopefully I've managed to attach my file! Regards, Amanda
    • devmap.txt
  • Quek
    Hi Amanda
    Thanks for the file. Actually I am also not aware of any method to get rid of the "subtype" property that gets created automatically. I think it should not cause any problems. If you really think that it should be removed, then perhaps using a skillscript to delete it from each device might a possible workaround.
    Quek
  • Amanda2
    Hi Quek,
    Thanks for your reply. I guess that confirms what I had initially feared!
    With kind regards, Amanda
    PS. I hope this reaches you as I cannot access the forums at the moment – Server Error in ‘/Community’ Application?
