  3. Adding New layer
  • Subscribers 136
  • Views 16905
Adding New layer
AnilKumar15
AnilKumar15 over 15 years ago
Hello ,
I am trying to add new layer (mask) in my layout. I tried to add the layer in my technology but when I stream-out it complains that "Failed to get Stream layer rules for layer-purpose pair `M14:drawing'.All objects on this LPP will be dropped".
Is there any simple full-proof way to include layer ?  My organization does not use any standard foundary and so I have control over the tech-files.
Anil K.
  • StefanSL
    StefanSL over 15 years ago
     Hi Anil,
    did you add the new layer to your layermap-file too?
    (the default layermap-file is located in your lib-directory and is named as the library itself,
    for example .../libdir/MYTECHLIB032S/MYTECHLIB032S.layermap )
    hope this helps
    kind regards
    Stefan
  • dmay
    dmay over 15 years ago
    If you are using 5.1.41, there is a section in the techfile to setup what layers get streamed out. Under layerRules there is a sub-section called streamLayers.
    Derek
