  3. calculator expressions for MOS Vth by max gm method
  • Views 18707
keble6
keble6 over 15 years ago
Hi, I am having trouble writing calculator expressions for this measurement. I suspect it's been done before!
I do a DC sweep of Vgs and measure Id. It's easy enough to find the value of Vgs where gm is max: xmax(deriv(IS("/vid/PLUS")) 1)
But more tricky now is to "draw" a tangent to the Id vs Vgs curve at thsi Vgs value and then calculate the x-axis intercept.
Any help appreciated!
  • keble6
    Aha, I solved it. Maybe not very elegant:
    (xmax(deriv(IS("/vid/PLUS")) 1) - (value(IS("/vid/PLUS") xmax(deriv(IS("/vid/PLUS")) 1)) / value(deriv(IS("/vid/PLUS")) xmax(deriv(IS("/vid/PLUS")) 1))))
  • tkhan
    tkhan over 15 years ago
    Is there any particular reason why you are using this method rather than obtaining vth from either Results>Direct Plot>DC Operating Points or Tools>Results Browser?
  • keble6
    Hi - I guess I could do that. My reason for using this method is that is what I'd done previously with another Spice simulator. It would be interesting to compare the results.
