  3. number of transistor's fingers as a variable in ADE L
  • Views 2967
jimito13
jimito13 over 15 years ago
Is there a way to define the number of fingers (nf) of a transistor as a variable in cadence environment?When hitting "q" and accessing the properties of the device in Schematics L it doesn't allow me to set a variable name under the nf option of the FET.
I would appreciate any helpful hint for this topic.
Thanks in advance,
Jimito13
    Jimito13,
    In general this should be OK, but if you have a poorly designed PDK where there are callbacks on the parameter value which assume that the value is a number, then it won't work (see The Dangers Of CDF Callbacks) . You should contact the supplier of the PDK and raise this with them - many PDKs manage to make this work OK. You didn't say which you were using.
  • jimito13
    Thanks for your reply.I was suspecting as well that this was might be a PDK matter because i've seen several schematics' screenshots that show the "nf" parameter annotated as a variable (and apparently they belong to another design kit).Well,i am using IBM's cms9flp (90nm).I don't think that i have a lot of chances if i ask IBM's support for this issue but i will take my possibilities ;-) Thank you very much again,i will check the solution you linked me above.
    Jimito13
  • tkhan
    tkhan over 15 years ago
    FYI unless you got the kit directly from IBM, they will not help you. If you're a 3rd party customer you must ask your fab/PDK provider (i.e. MOSIS, CMP, etc).
