  3. Digital vector stimulus outputs incorrect expected values...
  • Subscribers 133
  • Views 17920
Digital vector stimulus outputs incorrect expected values in the waveform dump
Satendra
Satendra over 14 years ago
I was running the ultrasim vector stimuls check for one of our design. I found that for some reason, the expected values in the waveform are shifted by one tunit.
I updated the ultrasim version from 7.1 to 10.1 but still the issue is not resolved. I would like to file this as bug. I have attached the waveform for your deep analysis.
The expected values are out of sync against the clock but comes in sync after some times(After the time cursor). However, when looking at the text file for the expected values, they should have aligned perfectly with the clock signal
    That's not the hostid (just the port and machine your license server runs on that). Why did you post that?
  • Satendra
     I have mailed to you
  • Satendra
    #            Customer Name:ARIZONA STATE UNIV
    #             Server  Name:0025643d0891
    #         Server  Location:United States
    #                  Host Id:0025643d0891
    #             Contact Name:Karamuir Chatha
    #               Contact Id:karamvir.chatha@asu.edu
    #                         :scott.lapora@asu.edu
    #                         :james.laux@asu.edu
    #                         :cherylm
    #                     Date:Wed Jul 20 09:34:22 PDT 2011
    #    Lic.File Generated By:cherylm
    #                 Comments:
    Why are you posting any of this? This is a community forum - nobody needs your hostid or indeed anything from your license file.
    If you were to use http://support.cadence.com and log a service request, you'd have needed to register using hostid Id:0025643d0891 - but that's for official Cadence customer support, rather than community support from volunteers (including some from Cadence)
  • Satendra
    Dear Andrew,
    I am sorry, I just removed it from that.  Hopefully you will be able to track the bug now and send me the fix.
    Satendra
    You appear to be under the mistaken impression that this is the Cadence Support site. It is not; it is the community forum. For official support from an application engineer, you need to go to http://support.cadence.com
