  3. Expanded devices
  • Subscribers 133
  • Views 15738
Expanded devices
Analog layout
Analog layout over 14 years ago
 Please any one tell me What is the meaning for expanded devices in LVS Window.
    Please read the Forum Guidelines . From your post above there is no indication of which tool you're using for LVS. Is it Diva, Dracula, Assura, PVS, Chameleon, Calibre, Hercules? Which version are you using?
  • Analog layout
     Sorry Mr.Andrew. I am using Assura for LVS & Virtuoso 5.1.4v
    In that case I assume you're talking about Expanded Cells? If Assura cannot match at a particular level of hierarchy, it will expand that cell and try to match at the level above and so on - this may be necessary if the layout hierarchy does not match the schematic hierarchy.
    That's covered in the Assura Physical Verification User Guide - if that's not it, maybe you can post a picture to illustrate what you're asking?
