  3. ocean XL - ocnxl test without analysis statement..
  • Subscribers 132
  • Views 2611
markbeck
markbeck over 14 years ago
Greetings all,
This is a bit of an esoteric question.  I wish to run an ocean-XL simulation with a group of tests that have no analysis statement within them. Let me explain:
I've created some ocean scripts which contain the 'includeFile' statement and within the included file, there exists some spectre simulation commands.  These are the commands which run the simulation. Now I wish to include these simulations within an ocean XL simulation for regression / corner analysis.  When I tried to blindly build and run with these tests, I found that ocean XL would complain:
"ERROR (ADEXL-1707): No analysis enabled for..."
If I place within the ocean test script a simple (analysis 'dc ?saveOpPoint t) statement, the simulation works as expected.  However, this is an unnecessary simulation from my standpoint since it doesn't contain the actual test. It's just there to make oceanXL happy.
Does anyone know a method to make Ocean XL run a test even when it doesn't contain an analysis statement within it?
Mark
    Hi Mark,
    This is done by the ADE XL "Lint" check which determines whether everything is consistent. I think it would be possible to hack things to turn off the check, but I'm not sure if there's a clean way.
    Best bet would be to log a service request - this seems a reasonable thing to be able to want to disable. It will probably need an enhancement to provide a cdsenv setting to control this.
  • markbeck
     Done: SR# 42654532
  • markbeck
    I actually found a nice (small) hack to bypass the lint checking.  Just have the scripts detect when an analysis statement is not included, then include a dummy analysis.
        ocnSetSilentMode(t)
        (unless (analysis)
          analysis('dc ?saveOppoint nil ?save "selected" ?maxiters 1 ) ; garbage dc bias...
        ocnSetSilentMode(nil)
    The analysis() statement satisfies the requirement that every OceanXL test includes an analysis statement(). However, by setting the ?saveOppoint to nil, it keeps that analysis from showing up in the input.scs file.  This will allow the stimulusFile() to completely define every analyses within an OceanXL test.
    Mark
  • markbeck
    markbeck over 13 years ago
    I found that they fixed this in the latest ISR (6.1.5.500.15) by adding in an environmental variable:  ignoreAnalysisCheck
    To use it: envSetVal( "adexl.simulation" "ignoreAnalysisCheck" 'boolean t)
    This works better than the hack, Yay!
     Mark
