  3. DRC Problem with assura.
  • Subscribers 133
  • Views 16134
Kabal
Kabal over 14 years ago
 We obtained IBM_PDK package with 7RF technology, i have installed it, it looked like it went well, the kit integrated in the Cadence environment adding its IBM_PDK menu etc.
Our cadence IC version: IC 6.14.005
Assura version: 4.1,  04.10.006-613
Now what i did is just copied simple element indx from base library to my new library, and then i select IBM_PDK->Checking->Assura->DRC  and it throws the following error:
master7MenuNotSupported("cmrf7sf" "MF" "ibmPdkRunAssuraDRC()" )
*Error* eval: undefined function - vuiDRCRun
<<< Stack Trace >>>
(... in ibmPdkRunAssuraDRC ...)
(... in master7MenuNotSupported ...)
master7MenuNotSupported("cmrf7sf" "MF" "ibmPdkRunAssuraDRC()")
ERROR
ddsAboutDFII()
I contacted MOSIS already, they said they did exactly the same thing but could not replicate a problem which i had, however they got only this message:
but other than that it worked fine for them.
 The only thing which they mentioned is to make sure that if i use IC 6.14 that my Assura is 4.1, but that IS the case.
my .cshrc does contain the lines adding the following PATH places:
$ASSURA/tools/bin
$ASSURA/tools/assura/bin
$ASSURA/tools/dfII/bin
and the LD_LIBRARY_PATH also set to:
$ASSURA/tools/lib
$ASSURA/tools/assura/lib
So it looks like all installed and set up well, then how come i get such an error? What could be the reason? Any suggestion for that?
Thank you!
  • Kabal
     well i tried again now with reinstallation, but that problem is still there... could anyone with experience with this software at least give me some approximate hint? Or tell me where else could i look at?
    thanks
    Two problems that I can see:
    1. I suspect you've not set $ASSURAHOME to point at the root of the ASSURA installation (you're using an env var $ASSURA). $ASSURAHOME is required so that virtuoso can find the installation in order to load code to implement the user interface.
    2. You appear to be using an Assura version built for use with IC613, but  are actually using IC614. I don't think this will be the cause of this problem (I just tried it and it worked), but it would be wise to use 4.1-614 (@(#)$CDS: assura version av4.1:Production:dfII6.1.4:IC6.1.4.500.10 09/21/2011 14:58 (vl-sfrh48) $)
  • Kabal
     Andrew, thank you!
     Your first assumption was right! I did not think that different name of variable could be a reason!
     Now i have some other problems, but i'll look at them, at least this part is done.
    thanks.
