  3. iPDK from TSMC 28nm pcell problems
  • Replies 7
  • Subscribers 137
  • Views 22617
Luc Laeveren
Luc Laeveren over 14 years ago
We're having difficulties with the usage of the two TMSC 28nm iPDK's in Cadence:
iPDK_CRN28HPL_v0.3_2a_20110715_all.tar.gz and t-n28-cr-sp-003-w1_1_0b_20110620.zip
During instantiating of a PCELL in layout XL we get following warning:
*WARNING* (DB-220704): The Pcell super master: tsmcN28/nch_mac/layout is not a SKILL super master.The usage of non-SKILL Pcells in Virtuoso is not a supported feature.
Though it's only a warning, no layout is created, only a red square is visible on the layout screen.
The installation went without any problem and we're using the exact same tool version as TSMC states in the Releasenotes;
Program:        @(#)$CDS: virtuoso version 6.1.4-64b 08/02/2010 00:21 (sjfnl002) $
Sub version:        sub-version  IC6.1.4-64b.500.6  (64-bit addresses)
I presume this has something to do with the phycells vs skill pcells? Do I need additional installation scripts or tools?
  • Quek
    Quek over 14 years ago
    Hi Luc Laeveren
    Actually TSMC iPDK for 28nm comes with both python-based pcells and SKILL-based pcells. You should not have a problem if you switch to SKILL-based pcells. : )
    Best regards
    Quek
  • Luc Laeveren
    Dear Quek,
    Thanks for the answer. During installation I can only select PYCELL.
    *Available PDK types:
    ************** Please choose PDK type  ***********************
       1 - PyCell             : support multi-platform
                                Cadence/Synopsys/SpringSoft/Magma/Mentor
    Please enter your choice:
    Do I need to do the switch later on? Or within Virtuoso?
    Kind regards, luc
    Luc,
    You should contact TSMC - they should supply the files for the SKILL version on request. That way you're not limiting the capability of the tools and are avoiding any support difficulties.
  • Luc Laeveren
    Thanks Andrew,
    Request is already sent to TSMC.
    Kind regards, Luc
  • berndf
    berndf over 14 years ago
     If you are going to use Python based parametrized layout cells form Ciranova in Cadence Virtuoso you either
    need to point to a Ciranova Plugin or to a Ciranova Pyros installation otherwise the PyCells will not be evaluated.
    Bernd
  • JukeBox
    JukeBox over 10 years ago
    Hi, I am using SKILL based pcells.There are two things that I would like to clarify.Firstly,I am not able to instantiate the layouts of any cell.I don't think that should happen.Secondly,if I try to change the 'w' or 'l' of any MOS , the changes are not being reflected in the schematic.What am I missing?
  • Quek
    Quek over 10 years ago
    Hi Shruti
    This thread has already ended in 2011. Would you please kindly post your questions in a new thread? This would also help us to focus on only your issue.
    Quek
