  3. installation problem?
  • Views 14636
ScottMC89
ScottMC89 over 14 years ago
Hi. I am a student at UT Dallas, we are using cadence design suite. I am copying
the basic CAD folder to my home directory. I ran DRC a couple times, it was working.
After the couple times, it gave me: error: parseString: argument #1 should be either a string or
a symbol (type template = "SS") - nil. It mentions techComp.cxt, I cannot find this file anywhere.
My thought was that maybe there was something wrong inserted into the file somewhere, but it
was not anything that I modified. Any help would be appreciated.
  • dmay
    dmay over 14 years ago
    You'll need more details about where the error message came from. Try setting these variables to get a stack trace on the error. Most likely, techComp.cxt is an unrelated print message.
    sstatus( stacktraceDump t )
    sstatus( stacktrace 8 )
    sstatus(traceArgs t)
    Some Skill command is calling parseString which expects a string for an argument and it is getting nil instead. The stack trace should point out the culprit.
    Derek
