  3. LSF jobs never finishing
  • Views 20963
BradW
BradW over 14 years ago
I've been using LSF to launch ADEXL jobs for some time now without issue but lately I've been having trouble with LSF jobs launched from ADEXL not finishing.  The individual APS jobs finish and I get results but I have to manually go kill a ton of jobs from the LSF queues because ADEXL doesn't seem to be cleaning up after itself.  Has anyone seen this before?
Here is some more detail.  On the "Job Policy Setup" I have
Start Timeout = 120
Configure Timeout=300
LingerTime=60
Also, I'm using the "Command" Distribution Method (not LBS).  I have to use the command because I need to reserve multiple processors and to my knowledge this isn't possible with LBS.  The specific command I use is
bsub -q medium -n 4 -R 'span[hosts=1]'
Any thoughts?
    What version (subversion) are you using? That shouldn't happen...
  • BradW
    Right now I’m running 6.1.5-64b.500.5
    Can you log a service request with customer support? This needs investigation, I think.
  • BradW
    Will do. Thanks for the quick response.
  • mhowell67
    mhowell67 over 14 years ago
     Hi Andrew,  I've also seen this issue and I can duplicate it reliably.  SR 42657658
    It only happens when using "command" distribution method.  The various options on bsub don't seem to matter.  I've done single runs with no multi-threading, corners with and without mt, and monte carlo and everytime the JOBID must be killed manually.
    Using LBS distribution method does not exhibit this issue nor have I seen this with ADEL.
    I've observed this behavior with several versions of 6.1.4 and 6.1.5.500.6.
    Almost forgot to mention.  This is not a case of the "lingering".  I can close all data, shutdown ADEXL and close my virutoso session and the JOBID will still be listed in LSF.
    Thanks - I'll keep an eye on the CCR that was filed with R&D for this.
