  3. error when running parametric simulations
  • Subscribers 133
  • Views 16631
dxt78
dxt78 over 14 years ago
I am using Cadence Virtuoso 6.1.3 and keep getting this error when trying to run a parametric (series of transient sims):
 ERROR (ADE-5759):
("renameFile" 2 t nil ("*Error* renameFile: invalid argument"))
 Thanks.
    I can only find similar errors in older versions (e.g. older IC5141 versions) - and in that case it was solved my moving to a newer hotfix.
    IC613 is not supported any more - you should see if the problem can be reproduced in IC615 (it's quite possible the same fix that was applied in IC5141 has been applied a later version), and if it can, please log a service request with Customer Support.
