  3. Finding Bus Range conflicts through schematic rules che...
  • Views 16677
Finding Bus Range conflicts through schematic rules check
markbeck
markbeck over 14 years ago
Greetings all,
I'm running IC6.15.500.6
I'm running into the situation where a designer might inadvertantly invert a bus without intending to.
If you have an instance with a port named "foo<1:0>" and you connect a wire to the port on an instantiated instance, Virtuoso will (by default) assign that wire a ascending port name "netxxx<0:1>". This causes the netxxx<0> to connect to port foo<1> and netxxx<1> connect to port foo<0>.
I know that you can set an environmental variable to define the order in which it is defined:  schematic netNameRangeDescend boolean t
However, I would like to add this sort of error to the standard checker that gets run when the designer does a "check and save".
I looked through the "Schematic Rules Checks Setup" dialog, but I couldn't find a pre-defined check.
Is there one?
Mark
    Mark,
    I'm not aware of such a check. This would be a good candidate for a custom check.
    Here's an example of using the new mechanism in IC615 to register schematic checks so that they are controllable via the Check->Setup Rules form (this is for doing some name case checks, but you can get the idea):
    /* abExampleSchematicCheckNew.ils
    Author     A.D.Beckett
    Language   SKILL
    Date       Oct 28, 2011
    Modified
    By
    This is a reimplementation of some of the checks in abExampleSchematicCheck.ils
    but taking advantage of the new interface in IC615 to register checks with
    the system. As a result it is much simpler, and does not have to take care
    of creating marker objects itself; also gives the user the ability to override
    the check, or change the severity if needed.
    To register, call:
    abRegExampleSchematicCheckNew("Your Customer Name")
    (with no arguments, it just calls the rule group "Customer")
    SCCS Info: @(#) abExampleSchematicCheckNew.ils 10/28/11.10:55:00 1.1
    ; The let is to create a lexical scope, so that there can be
    ; private functions which are used for some of the implementation
    let(()
        *  abRegExampleSchematicCheckNew([?customerName "Customer"])   *
        * PUBLIC GLOBAL function used to register the new check group  *
        * and any specific check - in this case an example of a naming *
        *                         convention.                          *
        defglobalfun(abRegExampleSchematicCheckNew (@optional (customerName "Customer"))
            ; This registers a new tab on Check->Rules Setup
            schRegisterCheckGroup(
                ?name concat(customerName)
                ?description strcat(customerName " checks")
            ; This registers the specific rule and default severity
            schRegisterCheckRule(
                ?title "Naming conventions"
                ?name 'namingConventions
                ?groupName concat(customerName)
                ?severity 'error
                ?checkCB checkNamingConventions
        *               checkNamingConventions(cv ruleObject)                *
        * INTERNAL function used to actually implement the naming convention *
        *                               check.                               *
        defun(checkNamingConventions (cv ruleObject)
            let((obj label netTable signals sigTable)
                ; Check that terminal names are in upper case
                foreach(term cv~>terminals
                    unless(term~>name==upperCase(term~>name)
                        ; Place the marker on the first pin - no need to
                        ; put it on every pin if there are multiple pins
                        obj=car(term~>pins~>fig) || cv
                        schReportCheckFailure(
                            ?object obj
                            ?checkRule ruleObject
                            ?short "Terminals not upper case"
                            ?message
                                sprintf(nil "Terminals must be in upper case: %s"
                                    term~>name
                    ) ; unless
                ) ; foreach
                ; Check for internal nets which have a lower case name
                foreach(net cv~>nets
                    ; Only worry about nets which have a label
                    label=car(exists(fig net~>figs fig~>objType=="label"))
                    when(label
                        when(exists(sig net~>signals
                            ; Check that the signal is not part of a
                            ; terminal, and is not in lowercase
                            !sig~>memTerms && sig~>name!=lowerCase(sig~>name))
                                ?object label
                                ?short "Internal nets not lower case"
                                ?message
                                    sprintf(nil "Internal net names must be in lower case: %s"
                                        net~>name
                        ) ; when there is a lower internal net name on net
                    ) ; when there's a label
                ) ; foreach
                ; Check for any nets which only differ in case
                ; record all the signals together in a table indexed by
                ; the flattened case. Then use a table to record all
                ; member nets which have a mixed-case problem
                sigTable=makeTable('sigTable nil)
                netTable=makeTable('netTable nil)
                foreach(sig cv~>signals
                    sigTable[lowerCase(sig~>name)]=
                        cons(sig sigTable[lowerCase(sig~>name)])
                ) ; foreach
                foreach(tableEntry sigTable
                    signals=sigTable[tableEntry]
                    ; If there was more than one signal with the
                    ; same flattened case, then there's
                    ; a mixed name problem. Record the member nets
                    ; in a table (to avoid duplication)
                    when(cdr(signals)
                        foreach(sig signals
                            foreach(memNet sig~>memNets
                                netTable[car(memNet)]=signals
                            ) ; foreach memNet
                        ) ; foreach sig
                    ) ; when
                ) ; foreach
                foreach(net netTable
                    ; Find something suitable to put the marker on
                    cond(
                        ; Use the pin if there is one
                        (net~>term~>pins
                            obj=car(net~>term~>pins~>fig)
                        ; Otherwise use the label
                        (obj=car(
                            exists(shape net~>figs
                                shape~>objType=="label"))
                            t
                        ; Next try a wire
                        (obj=car(
                                    shape~>objType=="line" ||
                                    shape~>objType=="path")
                            t
                        ; Finally, if nothing else, use the cellView
                        (t
                            obj=cv
                    ) ; cond
                        ?object obj
                        ?short "Net differing only in case"
                        ?message
                            sprintf(nil
                                "Net %L cannot differ only in case from others: %L"
                                net~>name
                                netTable[net]~>name
                ) ; foreach
            ) ; let
        ) ; defun checkNamingConventions
  • markbeck
    Thanks for the reply and the code example.  I had already written the custom check, but it seemed like such a standard thing to do that I was curious whether there was one built in and I just couldn't find it.
    Mark
