  3. mixed signal SpectreVerilog simulation
  • Subscribers 133
  • Views 15780
isazulkc
isazulkc over 14 years ago
I'm trying to simulate a top level mixed-signal circuit with SpectreVerilog. The analog/digital partitioning succeed. However, because I use the same power and ground for the digital and analog parts, simulation fails and I get this error:
"  net vdd! ... is a nonsupply global net that is also an interface net. Interface element is not generated for this net. You should use separate analog and digital stimuli for this net or classify the net as a supply (power or ground) net "
How to classify a net as supply if I don't whant to use separate power net for analog and digital blocks ?
Thanks !!
    You can specify which global nets are power and ground by going to Setup->Environment->Verilog Netlist Option and listing the Global Power Nets. Note however that an interface element will not be inserted on any global power or ground net - it will just end up connected to a supply1 or a supply0 in the Verilog.
    Any other global net which is on mixed nets will give the error you see above - partly this is due to the difficulty in inserting the interface elements (which could be at many places because of the reach of the global net). So you'll either have to have it non-global, or defined as a power net (as described above, but then it can't change throughout the simulation).
    Or you could use AMS Designer, which doesn't have this restriction.
  • isazulkc
    Thanks for your reply. It still have some problems related to bidirectional pins. So I'm going to try AMS Designer ...
    Thanks !
    KC
