  3. RE: modifying default trace properties for a dft in ade
  • Subscribers 133
  • Views 15590
jorankin
jorankin over 14 years ago
I am wondering how to change the default trace properties for a dft. Currently spectral traces show up for dft's in ViVA. I would like to change this in my .cdsenv file so that the default is lines. I tried to do this using the following command, but it didn't work:
wavescan.trace type string "line"
 I found the above command in the cadence documentation for ic 6.1.5. I don't see a similar command for viva...I tried replacing wavescan with viva in the above statement, but it didn't work.
John
    John,
    That won't help you because there's a hint on the waveform object produced by dft which overrides any default (and anyway I think that's an obsolete setting for the old Java graph - there's a CCR to get these removed from the docs).
    You could use the code below (comments at the top give a clue how to use it). Effectively wrapping your expression with abSetPlotStyle(... "joined") should do the trick, and there's a function to add this to the calculator to make it easier to use.
    /* abSetPlotStyle.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Dec 10, 2009
    Modified
    By
    abSetPlotStyle(waveform "joined")
    Sets a waveform to be plotted as joined. Can also be set to "bar" or
    "scatterPlot" or "auto".
    abRegSetPlotStyleSpecialFunction()
    registers a function in the calculator to alter the plot style on a
    waveform.
    SCCS Info: @(#) abSetPlotStyle.il 12/10/09.11:18:00 1.2
    *               (abSetPlotStyle wave plotStyle)                *
    *   Set the plotStyle to one of "auto", "scatterPlot", "bar"   *
    *     or "joined" (same as ocnHelp('plotStyle) choices) on     *
    *                   the waveform passed in.                    *
    (defun abSetPlotStyle (wave plotStyle "gS")
      (setq plotStyle (concat plotStyle))
      (cond
        ((drIsWaveform wave)
         (if (eq plotStyle 'auto)
           (remprop wave 'plotStyle)
           (putpropq wave plotStyle plotStyle)
        ((famIsFamily wave)
         (famMap 'abSetPlotStyle wave units)
      wave
    *                  (abCreateSetPlotStyleForm)                  *
    *  Set up a form for the special function on the calculator,   *
    * which gives choices for the plotStyle. It needs to be cyclic,*
    *   because if it's a type in field, quotes don't get added    *
    *                      around the units.                       *
    (defun abCreateSetPlotStyleForm ()
      (let (plotStyle)
        (setq plotStyle (ahiCreateCyclicField
                      ?name 'plotStyle
                      ?prompt "PlotStyle"
                      ?choices '("auto" "scatterPlot" "bar" "joined")
                      ?value "auto"
        (calCreateSpecialFunctionsForm
          'abSetPlotStyleForm
          (list
            (list plotStyle 0:0  180:20 140)
    *               (abSetPlotStyleSpecialFunctionCB)                *
    *    Callback for the abSetPlotStyle special function, which     *
    *     constructs the buffer input from the form and stack.       *
    (defun abSetPlotStyleSpecialFunctionCB ()
       ?formSym 'abSetPlotStyleForm
       ?formInitProc 'abCreateSetPlotStyleForm
       ?formTitle "Set PlotStyle"
       ?formCallback
       "(calSpecialFunctionInput 'abSetPlotStyle '(plotStyle))"
    *              (abRegSetPlotStyleSpecialFunction)              *
    *                Register the special function                 *
    (defun abRegSetPlotStyleSpecialFunction ()
      (calRegisterSpecialFunction
       (list "abSetPlotStyle..." 'abSetPlotStyleSpecialFunctionCB))
      t
