  3. Export DEF in IC61
  • Views 16604
Export DEF in IC61
Eduard Raines
Eduard Raines over 14 years ago
IC61 version 6.1.5.500.6
I am uisng  VXL
Guuys, I need some help to find out how can I define VDD,VSS as a special nets in exported DEF file in IC61?
Setting them as "power" and "ground" doesn't work.
Interesting thing is when I am routing them using Create Wire or from Navigator I don't get them SPECIAL, but when I route them by using Create->Shape->Geometrical Wire I DO GET THEM as SPECIAL.
The only differences I could find is my Create Wire net had Route Net Name = VDD,Geometrical Shape net had Net Name=VDD.
Did somebody have similar problem ? Does it  matter what routing strategy I am using and how in any case define SPECIAL net in IC61?
Many thanks,
Eduard Raines
  • Marc Heise
    Marc Heise over 14 years ago
     Hi Eduard,
    Wires created with the Create->Wire command will be real route objects like the ones you get when routing with
    digital P&R tools. So if you import such a design into an OA P&R tool, it can understand them and manipulate them.
    Every other type of shape  (rect, polygon, path, geom wire..) will be a SPECIALNET in the the DEF and handled differently
    by the P&R tools.
     So if you 'Convert to Polygon" your wire, you should see it as SPECIALNET" in your DEF.
    Or you could use the "Compose/Decompose Trunk" function in the Edit->Wiring menu. You should read the help about that because
    it is adding some more properties to the shape.
    Marc
  • Eduard Raines
    Hi Marc,
    Thanks a lot.
    Trunks work really nice.
    Is it a Cadence sugested way to define SPECIALNETS?
    In IC51 there was  sroute property to do that.
    Eduard Raines
  • Marc Heise
    Hi Eduard,
     I don't think we suggest an official way to do this. You just have to know that any shape
    not created with the Wire Editor will be a SPECIALNETS.  "Trunk" is from my experience
    the common name used for supply shapes, and you want to be able to connect to
    them on any point. So the "Compose/Decompose Trunk" seems to be the right way
    to go if the shape is previously created as Wire.
    Marc
