  3. Does PNOISE sim of a sample & hold circuit include clock...
  • Subscribers 136
  • Views 7439
Does PNOISE sim of a sample & hold circuit include clock jitter effect?
peter6g
peter6g over 14 years ago
I'm doing a time domain PNOISE sim of a sample and hold circuit with clock buffers.  Do the noise results include clock jitter due to the clock buffers?
    Andrew Beckett over 14 years ago +1
    Yes. You can think of the time domain noise (tdnoise) mode of pnoise as inserting an ideal sampler at the particular time instant at the output of the circuit - and then doing a pnoise as normal. Consequently…
    Peter, That's only the case if you are worried about large signal effects of the noise, which usually is not necessary. The noise in the system will have both AM and PM effects. Put another way (in a simple…
    Yes.
    You can think of the time domain noise (tdnoise) mode of pnoise as inserting an ideal sampler at the particular time instant at the output of the circuit - and then doing a pnoise as normal. Consequently noise generated earlier in the period (before the sampling event) can still end up being propagated to the output (e.g. stored on device capacitance or real capacitors and then transferred to the output). Because there's an ideal sampler present though, make sure you do not sweep beyond half the PSS fundamental, otherwise you will get multiple counting of the noise due to aliasing (this is only an issue when in tdnoise or PMjitter modes, not in normal "sources" pnoise mode).
  • peter6g
     But since the sampling clock thru the clock buffers "holds" the output of the sample and hold circuit, doens't jitter change the PSS result of the held output voltage?  It seems that sampling clock jitter and its effect of causing the held output voltage value to change is antithetic to what PSS is about, which is to converge to a periodic steady state solution.  And if what I've said is correct, then PNOISE would not account for the error voltage caused by clock jitter at the output of the sample and hold circuit.
     Thanks.
    Peter
    Peter,
    That's only the case if you are worried about large signal effects of the noise, which usually is not necessary. The noise in the system will have both AM and PM effects. Put another way (in a simple case), noise will cause small-signal variation in the position of an edge as well as small-signal amplitude variation. When worrying about jitter (or phase noise), we don't really care about the effect on the amplitude (if it were an oscillator, usually the AM noise is very small anyway because the oscillator naturally is amplitude limited; in some kind of switching system, you normally only care about the noise at a signal transition because it alters the decision point - anywhere else makes no difference) - so the various modes in pnoise allow you to investigate this. The jitter mode utilizes tdnoise automatically - it just places a sample at a threshold crossing, and then in the post-processing computes the noise as a jitter metric (e.g. in s/Hz^2 rather than V/Hz^2 or integrated equivalents).
    So if you're considering the noise (or jitter) as a small signal phenomenon, you don't have to worry about the alteration to the Periodic Steady State.
    For more details, see <MMSIMinstDir>/tools/spectre/examples/SpectreRF_workshop/JitterAN.pdf - also look at  Predicting the phase noise and jitter of PLL-based frequency synthesizers or the papers on cyclostationary noise here.
  • YutaoLiu
    YutaoLiu over 5 years ago in reply to Andrew Beckett
    Although this thread is 9 years ago, I find it is helpful to understand pnoise noise sim for switched-cap circuit.
    As you said that the total output noise of a track and hold circuit includes the clock jitter from the clock buffer, I have a question on interpreting the noise summary report.
    In the noise summary report, noise contribution is listed in a unit "V^2/Hz" or "V^2". What does it mean for the device in a clock buffer?
    Does the simulator convert the jitter (in unit of s) contributed by clock buffer to output voltage noise (in unit of V^/Hz)?
    Thanks and regards,
    Yutao
    ShawnLogan over 5 years ago in reply to YutaoLiu
    Dear YutaoLiu,
    First and foremost, I am not Andrew and am not attempting to respond with his insights and knowledge! Nevertheless, I thought I would try to respond to your questions to be best of my ability, albeit far less than Andrew's!
    The noise summary setup GUI allows for both "spot noise" and "integrated noise". The former is the noise, measured on a per Hz basis, for a particular offsets frequency whereas the latter is an integrated noise over a range of frequencies. Hence, the units of the result will be either in V^2/Hz or V^2 depending if the result is a spot noise or integrated noise respectively.
    The options for the noise summary function are defined on page 262 of the Product Version ICADVM20.1, March 2021 Ocean reference manual at the Cadence  On-line support URL:
    https://support1.cadence.com/tech-pubs/Docs/oceanref/oceanrefICADVM20.1/oceanref.pdf
    and discusses the available summaries and their associated options. This may be helpful to your understanding YutaoLin.
    I believe it does as the simulator output noise computation is based on the steady-state output waveform which will be dependent on the clock buffer as it controls the manner in which the track and hold switch introduces noise.
    Is there a reason you think it will not be included?
    Shawn
    The clock buffer is nothing special - it doesn't generate "jitter" and it has to be converted to V/sqrt(Hz) or V^2/Hz. The simulator deals with noise voltages and currents, some component of which is amplitude modulated and some component of which is phase modulated. It computes the transfer function from each noise source to the output (where noise is being measured) and multiplies that by the amount of noise at each noise source, then adds up the noise powers (taking into account any correlations when it does so). You might then choose to visualise that as a conventional noise (in V/sqrt(Hz) or A/sqrt(Hz) or the equivalent powers), or you might convert it to a time-domain metric. The simulator itself is not modelling the noise sources as a jitter quantity though.
    Does that help?
