  3. effective length variation after Monte Carlo trial
  • Views 17582
inessadm
inessadm over 14 years ago
Hi, when I run a Monte Carlo analysis in Cadence Spectre-v 6.1.3 (process only), I'm looking for the variation effect
on each nominal length (L effective) of the circuit's transistors.  I find only the varied process data corresponding to
a particular run but nothing about width or length chosen for a trial !
Is there any way to do this please ?
Another question : what the meaning of process data as wd108, wd015, and so on ?
Thank you.
  • Quek
    Quek over 14 years ago
    Hi inessadm
    You can print the actual values of the statistical parameters as follows:
    a. In ADE-XL results tab, switch to "Detail" view
    b. Right mouse click at the value column and select "Print Statistical Parameters"
    I am afraid that it is a little hard to guess what "wd108" means. Perhaps you might want to look in the PDK documentation or provide more details on where they are found (in model file, in spectre netlist, etc). If it is one of the parameters that appear in the statistical section of your model file, then it is simply a parameter that the foundry uses for varying the characteristics of a device during monte carlo. Foundry customer support should be able to provide more info on this.
    Best regards
    Quek
    Quek - you beat me to it!
    In addition, it would only vary the length if the length of the devices was influenced by a parameter which had a statistical variation associated with it in a statistics block (see "spectre -h montecarlo") - and I've not seen that done very commonly in PDKs. Usually it's model parameters that are varied - although it could potentially be done with some of the model parameters that affect deltaW and deltaL - if so you'd be able to annotate the weff/leff parameters (from the same right mouse button menu that Quek pointed to) for a specific point - and then you'd be able to see on the schematic what the effective length for a specific device was. However, this assumes that the effective length was actually altered by the models. Note you'd probably also have to use the Edit->Component Display form to alter what is annotated on the schematic.
    BTW, stating what PDK you're using might mean that somebody familiar with that specific PDK might be able to give some more detailed advice - but the documentation for the PDK is a good place to start.
  • inessadm
    Thanks for your quick reply !
    I don't see the detail view but only the default view ! Unfortunately, the 'print statistical Parameters' on the default view and the 'result Browser' give me anything about leff or weff. Do you know where could I possibly find documentation about the way to display parameters data as leff?
    Thanks !
    best regards
    inessadm
    You must be using an old version (e.g. 6.1.3 or 6.1.2) because it was renamed from Default to Detailed some time ago.
    Anyway, as I said, you won't see leff in the statistical parameters if it is not being statistically varied.
    I was mistaken about annotating it on the schematic. The leff should be in the "output" parameters in the result browser - you can enter this expression in the calculator and then plot it (assuming  you've saved family data on the Monte Carlo options form):
    pv("/I7/M3" "leff" ?result 'output)
    Note that /I7/M3 is the hierarchical path to the device in the schematic. If I do this, I see the effective length of that transistor versus the iteration number. In my case it doesn't vary because it's not a statistical parameter...
  • inessadm
    I've got only "dc operating points" or "design parameters" folders but anything about "outputs parameters" in my result browser ! I have to add specific option to view it ?
    inessadm
    Double click on the test name in ADE XL to bring up the Test Editor, and then do Outputs->Save All. I suspect that "Save output parameters info" has been turned off.
    That said, this is extremely unlikely to help you, because the chances are the length is not being altered by the statistical models.
