  3. AMS: Grid not seen in Waveforms
  • Subscribers 133
  • Views 15056
medeepak
medeepak over 14 years ago
Hi
I imported a Verilog code for not gate and tried to simulate it by giving a pulse signal as input varying from 0 V to 5 V.
I tried to simulate it using AMS simulator in ADE L
In the output waveform i get doesnth have any value on y axis and the Show Grid button is disabled
 Can anone guide me about to correct this
Thanks in advance
 Regards
deepak
    You didn't really give much information to go on - see Forum Guidelines.
  • medeepak
    Hi
    I am sorry fr giving less details
    i tried to import a Not Gate verilog in to Virtuoso (IC 6.1.3.1) through the verilog in form
    the not gate code :
    module notgate(b,a);
    output b;
    input a;
    assign b =~a;
    endmoudule
    after i imported it i created a schematic cell view with the input of not gate as a pulse voltage source (voltage varying from 0 to 1.8V with rise time 1ns, fall time 1ns, pulse width as 5ns and time perion as 10ns)
    and the output was attached to an output pin
    later i created its config view with AMS template
    in the ADE L window i selected AMS simulator, gpdk.scs as model library ans spectre as solver
    when i do run the ADE i get an output waveform that has no values in its y axis
    my specctre version is 78.2.0
    what could be the possible source of error
    if i had missed any piece of information kindly point it out
    regards
    deepak
